Key stuck in ignition
Discussion in '2nd Gen Tundras (2007-2013)' started by PhilT, Jun 8, 2018.
  1. Jun 8, 2018 at 3:27 PM
    PhilT
    PhilT [OP] New Member
    Phil
    13 Crewmax
    Who are here know how fix it for cheap in OC?
  2. Jun 8, 2018 at 3:33 PM
    TheBeast The Beach
  3. Jun 8, 2018 at 3:35 PM
    15whtrd
    15whtrd Mr. Blonde
    Ok I have to ask the obvious sorry. Is the truck in park?
    boostedtrdpro and Bprose like this.
  4. Jun 8, 2018 at 3:45 PM
    PhilT
    Phil
    13 Crewmax
    yes, I can't get the key out, but I can turn ignition on and off
  5. Jun 8, 2018 at 3:52 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm assuming you tried cycling the gear shift through all the gears and back to park. My Jeep did this occasionally and smacking the end of the key worked most of the time, the tumblers would get dirty and wouldn't release.
    Fiestee23 and 15whtrd like this.
  6. Jun 8, 2018 at 4:52 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Push in while turning key?
  7. Jun 8, 2018 at 5:13 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Pull down on the steering wheel as hard as you can like you are trying to turn and pull the key out?
  8. Jun 8, 2018 at 6:29 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Is there a release in the steering column? Somewhere to stab a long pick?
  9. Jun 8, 2018 at 7:24 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Get it out??
    15whtrd likes this.
  10. Jun 8, 2018 at 7:44 PM
    PhilT
    Phil
    13 Crewmax
    Yes, I did
    15whtrd likes this.
  11. Jun 8, 2018 at 8:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Come on man don’t leave us hanging! What was the culprit?
    Fiestee23, jewsNbrews, Krezz and 2 others like this.
  12. Jun 8, 2018 at 9:35 PM
    PhilT
    Phil
    13 Crewmax
  13. Jun 8, 2018 at 9:52 PM
    TheBeast The Beach
    do you have column shifter too ?
  14. Jun 9, 2018 at 5:35 AM
    PhilT
    Phil
    13 Crewmax
  15. Jun 9, 2018 at 5:54 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Hope it's not an issue with floor shift.
  16. Jun 9, 2018 at 8:43 AM
    PhilT
    Phil
    13 Crewmax
    I called the dealer told them what was happen to my truck, they quoted $470 replacement the ignition lock. I took some the steeling wheel cover off and unplug the couple cables, spray it with fuel injector and air pressure spray it work like a champ again
  17. Jun 9, 2018 at 8:47 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
  18. Jun 9, 2018 at 9:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Love it!:rofl::rofl::rofl:
    Krezz[QUOTED] likes this.
  19. Jun 10, 2018 at 7:02 AM
    PhilT
    Phil
    13 Crewmax
    Have anyone here convert to push start?
  20. Jul 23, 2019 at 8:56 AM
    FrankTXTundra
    FrankTXTundra New Member
    On my 2011 which has a column shifter I had the same issue. I couldn't take the key out after starting my truck. You could turn it off and on but couldn't turn past ACC in order to remove the key. I found that there was a little "ignition switch" that is actuated by the Actual shift lever when you put it into park. That switch wasn't making enough contact due to it wearing down over the years (it's made of plastic....). So a quick fix to get my key out was to unplug the wire harness from the ignition lock solenoid which has pretty easy access. This will release your key. Obviously the correct way to fix this is to replace the little ignition switch (I just went to the junk yard and got what I need). But, if you're in a jam all you need is a screw driver to remove the plastic trim on the bottom of the steering column in order to unplug the wire that will release your key... and yes your truck will still operate with that wire unplugged. The intent of that ignition lock is so you don't accidentally take your key out when your'e not in park. I posted a link to a video below:
    https://youtu.be/0EcgsigaQZU
  21. Jul 23, 2019 at 10:30 AM
    War Machine
    War Machine SSEM # 5 3MW
    Sometimes you gotta jiggle the steering wheel around to get the key out. It’s happened with both of my Tundras.
    15whtrd likes this.
