Key FOB 2007
Discussion in '2nd Gen Tundras (2007-2013)' started by ARayT, Jan 7, 2022.
  1. Jan 7, 2022 at 2:30 PM
    ARayT
    ARayT [OP] New Member
    GEORGIA
    2007 Tundra XSP
    Can a 2007 tundra key fob be programmed without going to the dealer, I've been told yes and no. I'm having problems w/ my FOB, changed the battery (twice) cleaned it w contact cleaner and it still works about every 5th time. Question about programming w/o dealer, I have a couple other toyota FOBs would like to program them if possible. Any help would be appreciated. Thanks Ray
    Where is the sensor on the truck located?
  2. Jan 7, 2022 at 2:36 PM
    Taco-Spike
    Two Trucks
    You can do it with techstream and a windows laptop. Not sure which OS for windows but I think there is a certain one.
    I think locksmiths can as well, worth a call to see
    edit: 2007, not sure where the sensor is
  3. Jan 7, 2022 at 3:33 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Thanks Taco-Spike, I wish I had a copy.
    Does anybody know if there is a way it can be done by the owner?
  4. Jan 20, 2022 at 2:06 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Can a 2007 tundra key fob be programmed without computer or dealer/ my the owner?
    Thanks Ray
  5. Jan 20, 2022 at 2:08 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Yes. A web search will bring up the procedure.
  6. Jan 20, 2022 at 2:28 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Audiowise, Thanks!
    I watched tube with several being programmed but none are 2007 models. The only 2007 i could find was accomplished w a code reader. Several say it will work w 2007 but what they are all showing is never a 2007. I've tried their procedures (door open, key in out, lock unlock....) more than 5 times with three different remotes w/o success.
    Has anyone w a 2007 ever been able to make this work? Really appreciate the help.
  7. Jan 20, 2022 at 2:36 PM
    Barnstormer
    Barnstormer New Member
    Having tried this with my 2007, I haven't been successful with any of the ways that don't use a laptop running Techstream. None of the "key in, out, door open/close, etc..." methods work for 2007-on.
    You have to use the programming software- either you or the dealer / locksmith, etc..
  8. Jan 20, 2022 at 2:44 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Barnstormer Many Thanks! Guess I'll be looking for a locksmith. Thought I was loosing it, trying those 37... different steps.
    Thanks Again, Ray
  9. Jan 20, 2022 at 4:08 PM
    audiowize
    Paul B.
    The list of steps will work but it's not super easy to do. It may take 5-10 tries to get it to work properly.
  10. Jan 20, 2022 at 4:19 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Hey @ARayT if you are around the Atl area come over to me. I have Techstream and can program the keyfob. I ping u via direct message.
