Kenwood DMX1057XR Won’t Power Up / Turn On
Discussion in 'Audio & Video' started by KenKenKen, Oct 19, 2020.
  1. Oct 19, 2020 at 9:43 PM
    KenKenKen
    KenKenKen [OP] New Member
    Ken
    2017 Tundra Platinum
    ARE Toneau
    So I installed my new head unit...
    The wiring hardness is soldered so I know I don’t have any bad connections.
    I have confirmed 12v continuous and accessory.
    I’m leaning toward suspecting a DOA head unit.
    Gonna call Crutchfield in the am. Any thoughts?
    I even tried moving the screen forward to make sure that the bezel wasn’t interfering. No luck.
    TIA
  2. Oct 19, 2020 at 9:45 PM
    AZBoatHauler
    So.Arizona
  3. Oct 19, 2020 at 9:53 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you check your 15 amp fuse in the HU?
    KenKenKen[OP] likes this.
  4. Oct 19, 2020 at 10:15 PM
    KenKenKen
    Ken
    ARE Toneau
    this has got to be it. Stupid piece of plastic. I’ll check first thing in the sm. Thanks!
    (Checked all fuses.)
  5. Oct 20, 2020 at 5:32 AM
    KenKenKen
    Ken
    ARE Toneau
  6. Oct 20, 2020 at 9:31 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Yup made the same mistake....
  7. Oct 20, 2020 at 11:43 AM
    KenKenKen
    Ken
    ARE Toneau
    Whatever...
    619Tundra and PWMDMD like this.
  8. Oct 13, 2021 at 8:30 PM
    Pilotsfaith22
    Pilotsfaith22 New Member
  9. Oct 13, 2021 at 8:36 PM
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    I have been watching for crutchfield to have this in stock for months. When did you purchase yours??
    Damie Street likes this.
  10. Jan 8, 2022 at 8:17 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Curious if anyone has any ideas for me to check on this? The protective cover above is installed and mines not powering up. I’ve got a text into the seller and we’ll see what he comes up with for troubleshooting. Things I’ve checked so far…
    Protective cover (installed)
    15 amp fuse on HU
    12v constant at yellow all the way to HU (13.57v)
    12v ACC power doesn’t appear to be present at red wire to HU
    Maestro RR2 seems to blink for a second then goes dark when turned on.
  11. Jan 9, 2022 at 10:15 AM
    boostedtrdpro
    Jeremy
    Does anyone know on the 2019 where I would find 12v ACC power that would translate to the TO2 harness down to the head unit? I’ve bench tested the HU and it’s for sure working. I’ve also checked the fuses in the cab and they all appear good. I’d like to be able to test for the 12v ACC power at the factory harness to make sure the problem is in the aftermarket harness and my wiring. Thanks guys.
    Pics of my factory connectors.
  12. Jan 9, 2022 at 10:23 AM
    boostedtrdpro
    Jeremy
    Honestly, I think my problem might be related to the Maestro. It looks like the red wire from the aftermarket HU harness goes to the Maestro power input. If I look at where the TO2 harness plugs into the factory harness, the only red wire on that connector (with the yellow and black), is red/black and it also goes to the Maestro. It’s like the ACC power is passing through the Maestro but not making it to the HU if that makes sense. Can anyone who knows verify this? Maybe I missed plugging something in the Maestro. There’s lots of empty plugs left on the Maestro.
  13. Jan 9, 2022 at 11:52 AM
    boostedtrdpro
    Jeremy
    Got it, firmware on the Maestro didn’t take the first flash. Working like a champ now!
  14. Jan 9, 2023 at 8:56 PM
    rainproofjeans
    rainproofjeans New Member
    Tyler
    Birmingham AL
    2012 Green DCLB 4x4
    I know this is an old post, but thanks for this. Totally missed those notes in the instructions and skipped that cover thinking I wanted to test everything before putting in all 6 screws plus the cover.
    After trying several RR resets, reflash, double checking wiring, finally ran across this thread… Immediately knew that was the problem. Thanks again!
    AZBoatHauler[QUOTED] likes this.
  15. Jan 21, 2023 at 2:04 PM
    Broj92
    Broj92 New Member
    Brandon
    Denver, CO
    2012 Red Tundra SR5
    Hey Jeremy,
    I am having the same issue as you did, but flashing did not seem to solve my issue. Do you happen to have any photos of your TO2 Harness connected to your factory radio? I am not getting any power to my Maestro and thus my HU.
    Also, see you that are in CO. You happen to be in the Denver area?
    Thanks,
    Brandon
