KENWOOD DMX1057XR & Front Facing Camera Question
Discussion in 'Audio & Video' started by dkahs05, Mar 14, 2022.
  1. Mar 14, 2022 at 5:07 AM
    dkahs05
    dkahs05 [OP] New Member
    2020 Tundra TRD PRO
    Anyone with this head unit have a Front facing camera hooked up? I installed mine recently and most every time I brake to stop or slow down, the camera comes on then goes off when I start to accelerate. I have check the settings and they are unavailable for the front camera.
  2. Mar 14, 2022 at 5:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    How did you hook up the camera? Should have been signal and then power/ground.
    Power should have tapd into the accessory power.
  3. Mar 14, 2022 at 7:13 AM
    dkahs05
    2020 Tundra TRD PRO
    Yes, Power to the accessory, ground to the truck, Signal to the head unit.
  4. Mar 15, 2022 at 2:27 PM
    dkahs05
    2020 Tundra TRD PRO
    So let me tell you what I did. I switch inputs. I reflashed the maestro, the head unit had no update. And it still flashes front camera while braking. I have notice it only does it with Android auto.
  5. Mar 17, 2022 at 9:13 PM
    Tundrafan23
    Tundrafan23 New Member
    There is a setting that turns the camera on when below 7mph or 5mph (I forget which one), so you can use the front facing camera when you pull into a parking space. There is a setting on the radio to turn this off. Tomorrow when I am in my truck I will find the exact setting for you and how to get to it.
    dkahs05[QUOTED][OP] likes this.
  6. Mar 19, 2022 at 6:22 AM
    dkahs05
    2020 Tundra TRD PRO
    Is there a secret menu? I went through all the menus and couldn't find any settings you referred to.
  7. Mar 29, 2022 at 8:08 PM
    Ozcomm
    Ozcomm New Member
    Dean
    2021 TRD Pro
    Forgive me for jumping in on your thread, but I'm desperately looking for help...
    I have the Kenwood DNR1007XR installed and the Android Auto keeps dropping out. I can't even take a short local trip without it dropping out, sometimes even restarting the unit! I've updated the firmware on 3/27/22 with no change. It happens weather I have my phone plugged in via USB or over Bluetooth.
    Any ideas?
  8. Mar 30, 2022 at 6:50 AM
    dkahs05
    2020 Tundra TRD PRO
    What kind of phone? And has you phone and app. been updated? To me it sounds like your phone. Do you have a old Android phone or someone else phone that you could test?
  9. Apr 21, 2022 at 9:02 PM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Same head unit and I have same issues. Which is odd since speed sensor isn’t connected.
  10. Apr 28, 2022 at 6:04 AM
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    This is normal behavior of the unit and you can't turn it off even though there's a menu option that seems it would.... It does not.
