KC Cyclones installed in the bed
Discussion in 'Lighting' started by ProtoJ, Jun 21, 2019.
  1. Jun 21, 2019 at 8:56 AM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    I'd like to install a pair of KC Cyclones in the bed of my truck. I have a couple of questions.....does anyone know how these lights attach...It would be nice to connect them in the bed rail system using someones bed rail pod brackets...like Rago. Second, I have a topper so my factory bed light switch is semi useless as the topper blocks it. Is there an easy way to tie into this circuit so that I can turn these lights on with this switch? Or is it better to just add another switch? Im currently out of switch blanks.
  2. Jun 21, 2019 at 9:03 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    They mount using a bolt through the center hole. Mine are attached to the factory rail system using t nuts I purchased from Amazon. Ill add a link later.
    CaptSpaulding and Black Wolf like this.
  3. Jun 21, 2019 at 9:09 AM
    Get with @mattgecko on his bed lighting, I had one Cyclone light, I didn't like the light output
    mattgecko likes this.
  4. Jun 21, 2019 at 9:15 AM
    ProtoJ
    I actually have a set of those T-nuts!
  5. Jun 30, 2019 at 9:59 AM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    I was looking into the Baja designs dome lights with the switch built in for some bed lighting. Mounting them to the bed and not the bed rail. I’m assuming they could be tied into the tail light circuit somehow so there would not be a lot of wire to run. A little more pricey but looks like a good option.
