K&N 63-1058 installation question
Discussion in 'Performance and Tuning' started by Psivector, Jun 4, 2017.
  1. Jun 4, 2017 at 8:20 PM
    Psivector
    Psivector [OP] New Member
    2004 toyota tundra limited
    Cold air Intake Borla Exhaust system
    Hi all, I have a 2004 Toyota Tundra Limited and I recently bought the 63-1058 cold air intake system and it came with two hoses. My question is what purpose do they serve if any? When I drive my engine doesnt overheat or have issues but I would like to follow the manual as much as possible.
    Attached is half of the image im trying to reference. They are parts G E and F. I recieved only two hoses bear in mind.
    Thank you in advance.
  2. Jun 4, 2017 at 9:10 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome! According to the installation instructions it looks like you should have all 3 hoses. Not sure what all 3 are for, I would think that one is a crank case breather, the other two?? Probably some kind of vent lines. In any case you're going to want those. They're supplied because the stock lines are usually too short to be reused. You should also make sure that the fittings that thread into the intake tube are there as well. You'll need those to connect the hoses. If it's only one hose that you're missing I'm sure you can get it from K&N but the quicker route is to hit an auto parts store that carries bulk vacuum hose and pick up a foot or so of the correct size. K&N's specification is inside diameter.
  3. Jun 15, 2017 at 12:20 PM
    Psivector
    Sorry for the late reply. I appreciate the advice i went to my local O Reillys and they cut a hose for me.
