just wont start
Discussion in '2nd Gen Tundras (2007-2013)' started by charles1114, Nov 11, 2019.
  1. Nov 11, 2019 at 2:59 PM
    charles1114
    charles1114 [OP] New Member
    chuck
    Newark De
    2012 gray tundra crew 5.7
    Hi, need some info, i have a 2012 5.7 tundra with 135,000 miles never had any issues...yesterday i went to start truck and it clicked when i turned the key. I just recently purchased a new battery and the electronics were working fine...tried several more times to turn the key just clicked. Tried one more time and it started...I have tired several more times today all was good, drove the truck for 4 miles shut it off went back and hour later it wouldn't start . this time after numerous attempts it still would not start. I am thinking its the starter but it is not spinning. any ideas would help thxs
  2. Nov 11, 2019 at 3:02 PM
    Alternator???
    OR18TRD likes this.
  3. Nov 11, 2019 at 3:08 PM
    Speedkills119
    Speedkills119 Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    Is the battery charging? Clean terminals? Is everything else working (radio, AC fan, etc...) when you turn on the key? If that's all good maybe the starter or starter solenoid.
    GODZILLA likes this.
  4. Nov 11, 2019 at 3:42 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Starter.
    GODZILLA and Jim LE 1301 like this.
  5. Nov 11, 2019 at 3:43 PM
    Starter or starter solenoid.
  6. Nov 11, 2019 at 3:44 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I would say starter as well and possibly a bad battery. It happens. May want to load test it to rule it out.
  7. Nov 11, 2019 at 3:46 PM
    TheBeast The Beach
    ever changed the spark plugs ? is it colder than usual ?
  8. Nov 11, 2019 at 4:26 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    If you could get at it, I'd whack the starter with a hammer (not hard) and try and crank it. If it's warm or smells like electrical, it's likely the starter. Most say it's a PITA to replace.. Go OEM.
    TheBeast likes this.
  9. Nov 13, 2019 at 8:19 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    Since you just put a new battery in, I would start there.
    Loose battery connection, broken clamp, or a dud battery? Check connections, take battery to autoZone and have the battery tested. Then go from there.
  10. Nov 13, 2019 at 9:09 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    This
    OR18TRD[QUOTED] likes this.
