Just ordered 3/1 lift. Torque specs and breathers question
Discussion in 'Suspension' started by dumbassdave, Oct 28, 2016.
  1. Oct 28, 2016 at 9:01 AM
    dumbassdave
    dumbassdave [OP] Member
    Dave
    2016 Crewmax Limited
    I just ordered the Toytec Ultimate lift and I am very excited about it. I had the same one on my Tacoma and thought it was awesome.
    On Tacomaworld.com I was able to find a list of all the torque specs, but haven't found that here. Does anyone have the torque specs for the 2nd gen Tundras? If not all of them, I guess I am looking for specs on the lower front shock bolts, shock tower nuts, u-bolts, and I guess maybe the front sway bar.
    If you have them and don't want to post it for some reason..... dumbassdave@hotmail.com
    Also, has anyone who has done 3" in the front found that anything wasn't long enough, such as the front diff and transmission breather hoses?
    Thanks for any help that comes my way!
    T-Rex266 likes this.
  2. Oct 28, 2016 at 9:42 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I got all my specs on the installation manual. If they don't have it (which they should) you can look at a readylift install video on YouTube. If I remember, they put the torque specs in subtitles on each part they were putting in at the time.
  3. Oct 28, 2016 at 9:44 AM
    dumbassdave
    Dave
    Thanks! If they don't send specs with it I'll certainly take a look there.
    Law323 likes this.
  4. Oct 28, 2016 at 12:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Tundra Torques
    Tie rod end: 51 ft lbs
    Top coilover bolts: 33 ft lbs
    Bottom coilover bolt: 144 ft lbs
    Wheel: 97 ft lbs
    Upper control arm ball joint: 81 ft lbs
    Steering knuckle: 81 ft lbs
    Sway bar bolt: 89 ft lbs
    Top stabilizer bolt: 111 ft lbs
    Lower control arm ball joint attachment(2 bolts): 221 ft lbs
    Lower ball joint: 123 ft lbs
    Aluminum wheel: 97 ft lbs
    Steel wheel: 154 ft lbs
    Control sensor wire A: 10 ft lbs on UCA
    Control sensor wire B: 21 ft lbs on spindle
    Sway bar brackets bracket (4 bolts): 51 ft lbs
    UCA through bolt for TC UCA: 173 ft lbs
    Uniball: 100 ft lbs
    Rear spring: 77 ft lbs
    Rear Ubolt: 74 ft lbs
    Rear shock upper: 21 ft lbs
    Rear shock lower: 66 ft lbs
  5. Oct 28, 2016 at 12:56 PM
    csuviper
    Broomfield, CO
    Lengths of everything work fine. Kit has all you need unless you want UCAs.
  6. Oct 28, 2016 at 12:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Dang Brian. You're just a tundra encyclopedia aren't you? LOL
  7. Oct 28, 2016 at 1:19 PM
    csuviper
    Broomfield, CO
    :muscleflexing:
    Law323[QUOTED] likes this.
  8. Oct 28, 2016 at 1:19 PM
    csuviper
    Broomfield, CO
  9. Oct 28, 2016 at 1:31 PM
    dumbassdave
    Dave
    That is fantastic!! Thanks for posting!
