Just joined to learn more about towing with my Tundra
Discussion in 'New Member Introductions' started by mgmoreau, Mar 2, 2019.
  1. Mar 2, 2019 at 3:30 PM
    mgmoreau
    mgmoreau [OP] New Member
    Marc
    2008 Tundra SR5 TRD 5.7Lt
    Hi,
    I have a 2008 Tundra SR5 TRD 5.7L. I just ordered an aluminum enclosed car hauler that I am picking up in one month. I have been reading this forum to see what other guys have done to their Tundra's to set them up to tow safely. I just ordered a pair of the Toyota OEM tow mirrors from a dealer in Miami on eBay. I am debating if I need to get a weight distribution hitch. The trailer will be approximately 3000 lbs dry weight and my two classic Datsuns weight about 2300 lbs each. Also the trailer will have 5200 lb torsion spread axles with 4 electric brakes. My truck is prewired and has the tow package. I have a 117,000 on the truck. Are there any mechanical things I should do before I tow this trailer home 600 miles?
    Thanks,
    Marc
  2. Mar 2, 2019 at 3:34 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  3. Mar 2, 2019 at 3:36 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
    040Tundra likes this.
  4. Mar 2, 2019 at 3:36 PM
    Welcome from NY.
    YES!! On the weight distribution hitch.
    Steve89gt and Pinay like this.
  5. Mar 2, 2019 at 3:45 PM
    Welcome from CO. @ColoradoTJ is our resident towing expert.
  6. Mar 2, 2019 at 3:47 PM
    Welcome
  7. Mar 2, 2019 at 3:54 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  8. Mar 2, 2019 at 4:03 PM
    mgmoreau
    Marc
    Thanks guys! From Rhode Island
  9. Mar 2, 2019 at 4:32 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    If you are hauling (2) Datsuns in an enclosed trailer, a weight distribution hitch and brake controller are needed. (not familiar if 2nd gens have brake controller)
    If possible, take time ahead of your journey to load balance trailer and ensure you get the right assist springs.
    Dont forget to setup and test the brake controller boost and gain when loaded.
    A tongue weight scale can help tremendously in ensuring your setup is correct. A trailer retailer can also help recommend the correct setup, just keep in mind they want to make money.
    While towing, keep the truck in 4S, it will rev higher and use more gas, but it keeps the torque converter locked up reducing trans temps.
    From a maintenance stand point:
    Has the truck ever had transmission serviced? Maybe recommend a drain and refill prior to trip.
    When was last diff fluid change? 30K+ Maybe recommend a drain and refill prior to trip
    Check tires and tire pressure.
    Check brakes and pads on both truck and trailer.
    On the trip, take your time, don't rush, leave plenty of braking distance.
    When planning your route, consider rush-hours if you pass through cities, adjusting departure time to miss peak traffic times can help tremendously on long trips.
    Good luck!:thumbsup:
    040Tundra and Eric104 like this.
  10. Mar 2, 2019 at 4:40 PM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    Welcome
    Pinay likes this.
  11. Mar 2, 2019 at 4:59 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from South Carolina
  12. Mar 2, 2019 at 5:10 PM
    mgmoreau
    Marc
    Hey Stuckinohio,
    Thanks for all this great feedback!
    I will only be towing one car at a time. I live in RI and picking up the trailer in Woodburn IN. It is a brand new aluminum trailer. I am towing it home empty so will only be pulling the 3000# dry weight trailer. I do plan to get a brake controller.
    Yes I had the transmission drained and refilled about 5000 miles back. I will have the diff fluid changed. I bought the truck used and it had 91,000 miles when I bought if from a Toyota dealer. It was a one owner truck.
    I appreciate all the information.
    Here are pictures of the my 2 Datsuns
    BestGen, Steve89gt, OR18TRD and 6 others like this.
  13. Mar 2, 2019 at 5:14 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
    Beautiful cars!
  14. Mar 2, 2019 at 5:17 PM
    flying dave
    flying dave New Member
    NC
    Wow. Love both of those cars. Very, very nice.
  15. Mar 2, 2019 at 5:24 PM
    mgmoreau
    Marc
    Thanks Fishman
  16. Mar 2, 2019 at 5:24 PM
    mgmoreau
    Marc
    Thanks flying Dave
  17. Mar 2, 2019 at 6:18 PM
    Welcome from Ohio.
  18. Mar 2, 2019 at 6:22 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    3k dry weight on the trailer will be a breeze for the truck, I also tow my show truck on my trailer which is about 7500lbs and I haven't had a need for a WDH with that setup but I'm pulling on an open trailer. You will have to see how your enclosed trailer handles and make a decision from there. These trucks pull very well and are very stable at speed while towing. As others said make sure fluids are up to date with there service intervals, other then that just enjoy the truck.
  19. Mar 2, 2019 at 6:40 PM
    mgmoreau
    Marc
    Thanks Andrew.
  20. Mar 2, 2019 at 6:42 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Welcome from AZ!
  21. Mar 2, 2019 at 6:44 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from NC.
  22. Mar 2, 2019 at 6:45 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    No problem, you will enjoy this truck for towing. I know mine is the best truck I've had for towing so far, its very sure footed and pulls with ease. Tow mirrors was a good decision on your part since going with an enclosed trailer.
  23. Mar 2, 2019 at 7:01 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Welcome from SC
  24. Mar 2, 2019 at 8:46 PM
    Welcome from Texas
  25. Mar 2, 2019 at 8:52 PM
    mgmoreau
    Marc
    Thanks guys.
  26. Mar 2, 2019 at 9:04 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Sin City!
  27. Mar 2, 2019 at 9:20 PM
    Aron9000
    Aron9000 New Member
    Aaron
    I'd say pop the wheels off and have a look at the brakes. Completely flush the brake fluid if you do change pads/rotors. These trucks should have zero slop in the pedal and stop very quickly and controlled if you mash the pedal all the way. The brakes really did impress me on this truck, it stops more like a normal 3300lb Camry than a truck. Drive some older Dodge Cummins trucks that can pull some serious loads, the brakes on those trucks suck compared to our Tundras.
  28. Mar 3, 2019 at 6:58 AM
    mgmoreau
    Marc
    Thanks for the advice Aaron, I will follow up on this.
