Just got the cavalry blue!
Discussion in 'New Member Introductions' started by dKinzer, Jan 1, 2021.
  1. Jan 1, 2021 at 11:21 PM
    dKinzer
    dKinzer [OP] New Member
    Just got the 2021 limited in cavalry blue with the trd off-road. I am already thinking of doing some bronze rims (method maybe?) open for suggestions!! Also just chrome delete. I am still trying to figure out what the biggest size tire I can fit without a lift and absolutely no rubbing. 285/70/18? Any suggestions are welcome! I am new to the toyota family (traded in my ram 1500) and looking for the best mod brands etc
    MTRock, YardBird, CavGirl21 and 8 others like this.
  2. Jan 1, 2021 at 11:26 PM
  3. Jan 2, 2021 at 12:37 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  4. Jan 2, 2021 at 12:52 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Welcome welcome
  5. Jan 2, 2021 at 1:07 AM
    2mchfun
    Welcome from OKC! Congrats on the truck!
  6. Jan 2, 2021 at 4:00 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from Maryland :hattip:
  7. Jan 2, 2021 at 4:22 AM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Welcome, nice truck! Check the wheels/tires sticky section, and you should have your answer. Great color choice :thumbsup:
  8. Jan 2, 2021 at 5:09 AM
    Welcome from Ohio
  9. Jan 2, 2021 at 5:15 AM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
  10. Jan 2, 2021 at 5:18 AM
    Zero One Actual
    Look at the 17 inch Icon Vector 5 in bronze. Saves you weight versus an 18 and has the perfect offset for our trucks.
  11. Jan 2, 2021 at 5:58 AM
    Blue Thunder
    Washington
    Welcome from WA
  12. Jan 2, 2021 at 6:06 AM
    18" TRD Off Road Wheels
    Welcome from Wyoming.
    Excellent color choice!
    As far as tires without rubbing, you will want to research in the wheels and tire threads because your wheel choice and even brand of tire will affect whether or not you will rub. Prime example, SCS Ray10 wheels have a +25 offset and a 275/70R18 Nitto Ridge Grapplers fit with only the little front air dams needing to be removed. The exact same wheels with 275/70R18 Falken Wildpeak AT3W tires had to have those same air dams removed, but also rubs at full turn in reverse. Not all tires are created equal. Some are true to size while others run a little large/small depending on manufacturer. If you are not lifting the truck then I would guess that 285/70R18 is going to be too large to avoid rubbing without modification.
    Edit: You should pop over to the Cavalry thread. https://www.tundras.com/threads/cavalry-blue-owners.59580/ lots of ideas there.
  13. Jan 2, 2021 at 6:41 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    This is from a thread on here which I have been going off, it explains every tire size you can have with stock, level and lift.
  14. Jan 2, 2021 at 6:44 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  15. Jan 2, 2021 at 6:48 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  16. Jan 2, 2021 at 7:40 AM
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    Welcome from Montana! I have the same setup as you, except mine is a 2019.
  17. Jan 2, 2021 at 7:42 AM
    CavGirl21
    CavGirl21 New Member
    Sheri
    Southern Wisconsin
    2021 Cavalry Blue Tundra Crewmax SR5
    Welcome from Wisconsin! My Cavalry blue rolled off the assembly line last week, just waiting for delivery. Great color selection! :thumbsup:
  18. Jan 2, 2021 at 8:07 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  19. Jan 2, 2021 at 8:47 AM
    georgiey22
    Initially Installed 285/70r18 with no lift and they certain rubbed. Added a 1.9” lift up front and a small mod and no more rub. Congrats on the new truck. You are going to really enjoy it.
    Hawk373 likes this.
  20. Jan 2, 2021 at 9:51 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
    275/70R18 is about as big as you’ll get with NO lift. That also depends on the offset of the wheels you get - my experience was with the stock TRD OR wheels that you have.
  21. Jan 2, 2021 at 9:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  22. Jan 2, 2021 at 9:58 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from PEI!
  23. Jan 2, 2021 at 9:59 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome! Priority 1 should be to unload all that chrome.
  24. Jan 2, 2021 at 9:59 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Cavalry Blue for the win!
    Awesome choice
    CavGirl21 likes this.
