Just got 2014-What Maintenance should I do?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Jan 1, 2021.
  1. Jan 1, 2021 at 6:26 PM
    Rocko9999
    Rocko9999 [OP] New Member
    Hello. I just got a 2014 DC 4.6L with 156K miles. I know the oil, trans fluid and rear end fluid were changed recently. Coolant was done less than 1 year ago. Plugs, belt, air filter within 30K. What else would you look at?
  2. Jan 1, 2021 at 8:06 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Not being an arse. Search functuon is your friend. Here ya go. https://www.tundras.com/threads/tundra-maintenance-guide.315/
    I would also check to make sure everything is greased under the truck, no rust on the frame that would need mitigation, as well as cleaning the mass air flow sensor.
    Rocko9999[QUOTED][OP] likes this.
  3. Jan 1, 2021 at 8:09 PM
    Rocko9999
    1UP[QUOTED] likes this.
