Just another inch
Discussion in '2.5 Gen Tundras (2014-2021)' started by ShawnTRD, Jul 24, 2023.
  1. Jul 24, 2023 at 10:29 PM
    ShawnTRD
    ShawnTRD [OP] New Member
    Shawn
    I'm thinking when I go to replace my shocks and struts on my 2020 Limited I want to stay almost stock. I wouldn't mind another inch higher in the front but the rear and stay as is. I still want some front drop. I was thinking Bilstein 5100. So do I pair then with a aftermarket coild springs?
  2. Jul 24, 2023 at 11:34 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    5100s use stock springs.
    I guess you could use an aftermarket spring but it is not needed.
    The 5100 has 3 settings that could adjust your front lift.
    This may or may not help.
    Pics of 5100s on Different settings? | Toyota Tundra Forum (tundras.com)
    You could use a .5" shim with the stock shocks.
    It would give you your 1-inch lift, but the naysayers will say it might overextend your front end, kinda like a 2.5" or 3" spacer lift.
    Kinda depends on if you plan to go offroad or if you're a pavement princess..:D
    Good luck...:thumbsup:
    WFD473 likes this.
  3. Jul 24, 2023 at 11:53 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  4. Jul 25, 2023 at 3:00 AM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Seat jackers and larger tires maybe?
