Just added 2" leaf springs
Discussion in '2.5 Gen Tundras (2014-2021)' started by CJ21, Sep 2, 2016.
  1. Sep 2, 2016 at 9:33 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    image.jpg Just added 2" leaf springs
  2. Sep 2, 2016 at 9:40 AM
    Truck looks great. How does it ride so far? Anything you would do differently?
  3. Sep 2, 2016 at 9:43 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Thank you. The rides is amazing I like the fact that it stiffened up the rear End. And if you go to haul or tow something you're not getting the sag in the rear End.
    14Tundra16 and zcarpenter92 like this.
  4. Sep 2, 2016 at 10:42 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Nice ride CJ, what's your total lift on that? I'm digging the ride height and what tire size did you go with?
    CJ21[OP] likes this.
  5. Sep 2, 2016 at 12:59 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Originally I started with a 7 inch BDS lift then I added a 2 inch leaf springs in the rear . Do to the fact that the rear was a little lower. Now it's a perfect height the rear sits about 1" higher than the front. And I ran 35" tires on 20x12 wheels. The wheels have a -44 offset.
  6. Sep 2, 2016 at 1:06 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    it seems like the all around favorite for the gen 3 is a 3in or a 7in. I've been wanting a little more stance and was debating on 1.25 spacers but I want to try and stuff 35's first. yours looks perfect man.
  7. Sep 2, 2016 at 5:34 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    If you do a all-terrain tire 35s you might be OK it's the mud tire the tread rubs . But you might want to try 2" leaf springs in the rear and a 1 1/2 inch block up from
  8. Sep 2, 2016 at 10:31 PM
    14Tundra16
    14Tundra16 ToyNot4Sale
    OG
    Ca
    2014 Limited CM 4x4
    8" FTS, 37 toyos, 20 Fuel wheels
    How much did you pay and labor for leaf springs ?
  9. Sep 3, 2016 at 7:17 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    $145 for the leaf springs $85 for install
  10. Sep 3, 2016 at 7:56 AM
    14Tundra16
    OG
    Ca
    2014 Limited CM 4x4
    What brand did you get,? Did you order online
  11. Sep 3, 2016 at 8:18 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Tuff country.. Is the brand name.
    No I did not order them online I actually ordered them from rhino lining of Delaware . But I'm almost positive you can get them off-line .. Look up Tuff country add a leaf ..
  12. Sep 3, 2016 at 8:24 AM
    14Tundra16
    OG
    Ca
    2014 Limited CM 4x4
    Thanks for the info
    Enjoy the long weekend
  13. Sep 3, 2016 at 8:36 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Anytime.. You have a great weekend also Brother!
