JT 02 Tundra
Discussion in '1st Gen Builds (2000-2006)' started by 01erionracing, Mar 5, 2018.
  1. Mar 5, 2018 at 1:00 PM
    01erionracing
    01erionracing [OP] KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    This is a 02 Tundra, I bought from a friend about 5 years ago. It has 243k miles when I bought it.
    This is a list that I have done in the past and now I am going to make it a mid travel and add more body armor.
    Roof rack
    Front winch bumper with Tuffstuff 12.5k lbs winch.
    Bed rack for dirt bike
    Bilstein 5100 series
    Bed rack
    Rock slider 1.5x4x3/16" square tube
    Shovel and axe mount on the truck bed driver side
    Hi-lift mount on the truck bed passenger side
    I also added 20 lbs CO2 bottle
    Odyssey 34r battery and the SS battery box
    2010 Mini cooper front seat
  2. Mar 5, 2018 at 1:11 PM
    01erionracing
    Jimmy
    The suspension parts....
    Camburg UCA arrived and installed
  3. Mar 5, 2018 at 1:11 PM
    01erionracing
    Jimmy
    Rear bumper removed and ready for the off road steel bumper
    New bumper is forming
  4. Mar 5, 2018 at 2:05 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Will be enjoying this build. Thought you were going with Fox instead of Bilstein?
  5. Mar 5, 2018 at 2:11 PM
    01erionracing
    Jimmy
    Bilstein 5100 has already in the truck over a year and it will be removed hopefully next week lol.
    zcarpenter92[QUOTED] likes this.
  6. Mar 5, 2018 at 2:13 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice looking truck buddy.
  7. Mar 5, 2018 at 2:13 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Fair enough! Don’t see many 1st gens with quality MT set ups, looking forward to hearing how she runs.
  8. Mar 5, 2018 at 2:16 PM
    01erionracing
    Jimmy
    So far I am very happy with Camburg UCA on the 1st off road test 45+ miles with multiple whoop section in Anza Borrego area.
  9. Mar 5, 2018 at 2:17 PM
    01erionracing
    Jimmy
    Thanks COMiamiFan
    TXMiamiFan[QUOTED] likes this.
  10. Mar 7, 2018 at 7:41 AM
    01erionracing
    Jimmy
    Progress on the rear bumper
  11. Mar 10, 2018 at 6:55 PM
    01erionracing
    Jimmy
    Update on the rear bumper
    Cutout for backup light, plate, receiver hitch, trailer plug and stop up.
    Boxed up
  12. Mar 10, 2018 at 7:06 PM
    TheBeast The Beach
    looking good !
    01erionracing[OP] likes this.
  13. Mar 12, 2018 at 5:28 AM
    01erionracing
    Jimmy
    Rear bumper finishing
  14. Mar 12, 2018 at 5:31 AM
    01erionracing
    Jimmy
    Open box the ADS shocks
  15. Mar 12, 2018 at 5:35 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Sweet setup brotha. Nothing like 100% custom fab!!!!
  16. Mar 12, 2018 at 5:42 AM
    01erionracing
    Jimmy
    Removing Firestone airbags
    32" BFG KO2 compared to 35" Mickey Thompson M/T Baja
    Stock height rear Bilstein shocks compared to ADS resi
    Rear shocks installed
    Front Bilstein 5100 ADS resi with clicker
    Front ADS shocks installed
  17. Mar 12, 2018 at 5:48 AM
    Excellent job!!
  18. Mar 12, 2018 at 5:48 AM
    Bad Ass!
  19. Mar 19, 2018 at 6:55 AM
    01erionracing
    Jimmy
    Making a skid plate with 3/16" mild steel
    Painted and mounted
  20. Mar 19, 2018 at 8:13 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    She’s looking good man!
  21. Mar 20, 2018 at 1:29 PM
    01erionracing
    Jimmy
    Roof rack tire mounting bracket, lockable is also an option.
  22. Apr 17, 2018 at 10:49 AM
    01erionracing
    Jimmy
    Update...
    This is a summary of the carnage on the desert camping trip 2 weeks earlier:
    Front diff carrier internal gear damaged.
    Broken rear driver lower shock mount.
    Lost the rear driver shock (ADS piggy back 3 weeks old) and broken rear driver ABS cable and parking brake.
    Ordered the front diff carrier from ebay on 113k Tundra same gear ratio. The part came from Minnesota so you know what to expect. I spent almost 2 days dipped in the vinegar and salt and it doesn't seem to help.
    I ended up rust removal wheel on the grinder it works.
    Remove the diff carrier alone.
    And installing it alone with my 13 years is old boy help the jack and the strap, it is finally installed.
    Few hours on the Friday late evening the front diff carrier installed and tested worked perfectly.
    Rheywood456 and Sunnier like this.
  23. Apr 17, 2018 at 11:02 AM
    01erionracing
    Jimmy
    The rear shock was ordered few days earlier from ADS and it arrived
    I also purchased rear diff protection from trail gear, this is 1/4" thickness.
    Installed
    Getting 1/4" shock mount tab from the supply store and built the rear shock mount for both side.
    The factory shock mount on the pass side
    The new one that I made
    New shock on the driver side installed and re-soldered ABS wire.
  24. May 7, 2018 at 7:17 AM
    01erionracing
    Jimmy
    I replaced both side inner and outer tie rod end due to some free play in it. Crescent adjustable wrench and 1 pipe wrench are able to handle the tie rod end.
    because_wumbo-truck likes this.
  25. May 11, 2018 at 10:43 AM
    01erionracing
    Jimmy
    Update,
    Recently I drove on long steep hill freeway with AC on 80+ MPH and ambient temp is about 95 -98, I see the engine temp creep up little bit and if I slow down a bit the engine temp go back to normal. Timing belt, water pump package, radiator and fan clutch was replaced about 50 k miles ago so I don't know if this is normal for 295k miles engine so I need to slow down when go uphill or something else's wrong.
    Anyway, I decided to add hood louver hopefully it will take some hot air out of the engine bay.
    Taped and drew the template
    Installed
  26. Jun 6, 2018 at 12:25 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    daaaaaamn dude! Can't wait to see this thing in person!
  27. Jun 7, 2018 at 6:38 AM
    01erionracing
    Jimmy
    Me too. Exciting to meet and wheel with SGU group.
    KevinK likes this.
  28. Jun 9, 2018 at 1:19 PM
    01erionracing
    Jimmy
    Picked up Deaver leaf pack and ready for the installation.
    Rear wheels removed ad ready to install
    Installed side view
  29. Jun 9, 2018 at 1:38 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Looking good Jimmy
  30. Jun 10, 2018 at 4:36 PM
    Casper421
    In the woods
    06 DC
    Nice! Is that the G57 10 pack?
