Jomax ABS Sensor Install!
Discussion in '2.5 Gen Tundras (2014-2021)' started by DZ_, Jul 30, 2020.
  1. Jul 30, 2020 at 5:54 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Received my set of ABS sensors from the recent group buy today. Thanks to 14burrito for organizing it!
    Impressions: very nicely designed, very nicely machined and finished. I think the two points of contacts makes a huge difference in comparison to single point of contact units.
    On to the install, a few photos:
    Tools for the fronts:
    (Right Front) Remove this clip(reinstall after mounting sensor cover):
    On!
    (note, clip reinstalled)
    Left front:
    On to the rear.
    Tools used:
    Removing the 17mm nuts:
    Position so the sensor wire is centered, not rubbing:
    Torque to spec:
    All done!
  2. Jul 30, 2020 at 5:57 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I left my clip on. Where we supposed to remove it? @14burrito
    HulkSmurf14, Toyotoholic and rebmo like this.
  3. Jul 30, 2020 at 6:01 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    But I agree two points of contact, the coverage area of this is well worth the extra $$. Also the fact that you re use the stock bolts and not use extended bolts is an extra plus. Really thought out product and well executed.
  4. Jul 30, 2020 at 6:12 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Yes, per the instructions #2, #3 and reinstalled per #15: https://jomaxcustoms.com/installation-guides
    Thanks, I clarified that I reinstalled them.
  5. Jul 30, 2020 at 8:13 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    LOVE IT!! :cheers:
  6. Jul 30, 2020 at 8:16 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I didn't remove my clip either. I think that was added in because (from their install experience) I think there were ever so slight deviations in the slack at the wiring there on that lip. Removing the clip and reinstalling prevented possible issues from "stretching the wiring". -- I think this is why it was added, not 100% sure offhand --
    *Meant to respond to @BlueBottle
    JC303 likes this.
  7. Jul 31, 2020 at 5:27 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    It also made removing and installing the 12mm bolt much easier. When I did the second front cover, I didn't bother popping the wire out of the clip(#2), just popping the clip off of the bracket (#3) was sufficient.
    14burrito[QUOTED] likes this.
