JL 10-TW3, Audiofrog,Kenwood DMX1037s Build
Discussion in 'Audio & Video' started by Desolate, Feb 17, 2021.
  1. Feb 17, 2021 at 8:19 PM
    Desolate
    Desolate [OP] New Member
    2019 White Crewmax Off Road
    Spent a few weekends over the last month upgrading the stereo in my Crewmax. Thanks to most of you who posted your installs for the inspiration!
    First was the DMX1037s from Cruthfield. I ordered all of the accessories to go with it as well. At this point the factory system was much improved but after trying to tune the factory speakers over and over again I decided I had to upgrade.20210131_170353.jpg
    Picture of the mic in the factory location in the overhead console20210131_112248.jpg
    Spoke with James @tech12volts and went with his custom tuned ported box with JL 10TW3-D4's. He also recommended the JBL A1000 which is 600 watts RMS @ 4 ohms. After waiting a few days for the box to be built I wrote James again and had him send me the Audiofrogs G60S front components.
    Killmat, Stinger sound rings and custom ABS speaker mounts. The stereo at this point with the Audiofrogs running off of the head unit sounded great! 20210216_071330.jpg
    Got some 1/4" ABS to make a amp rack and fuse holded for the engine bay. Ordered techflex tubing to protect all of the wires. Heat shrinked, soldered and wire ferrules where needed. Just finished up on Monday.20210215_140257.jpg20210215_140303.jpg 20210215_151633.jpg 20210215_182159_capture.jpg 20210215_193256.jpg 20210215_164612.jpg
    At this point I still have to find a way to mount the remote bass knob and get it tuned properly. I am sure I will get some rear speakers for fill and a 4 channel amp at some point.
    PNWTundra2021, Skew12, Rica25 and 4 others like this.
  2. Feb 17, 2021 at 8:43 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Clean install!
    Rica25 and Desolate[OP] like this.
  3. Feb 17, 2021 at 9:00 PM
    Freeezen
    Freeezen New Member
    Super clean install.
    Desolate[OP] likes this.
  4. Feb 18, 2021 at 10:37 AM
    KenKenKen
    KenKenKen New Member
    Ken
    2017 Tundra Platinum
    ARE Toneau
    Not sure if the user interface is different on the 1037 but the 1057 subwoofer adjust is easy to access so I don't feel like I need a bass knob. Might be something to consider for you, but I'm not sure. Maybe you are running a separate subwoofer RCA signal...
  5. Feb 18, 2021 at 1:35 PM
    MillMatter
    MillMatter New Member
    Pensacola, FL
    2014 1794 Edition 4x4 CrewMax Super White
    6” pro comp lift, 35x12.50 Toyo R/T, 22” chrome Fuel Hostage, Magnaflow custom dual in dual out exhaust with OEM chrome tips w/ Toyota logo, tint, smooth finish color matched fender flares, color match grille surround and hood bulge, 14-17 TRD Pro grille custom painted all white (letters remain matte silver), classic Toyota tri-color logo in grille (blue color scheme), chrome step bars, Century Sillhouette tonneau, Pendaliner drop in bed liner, custom company graphics, chrome TRD decals custom painted to color match company graphics (blue), ESP under seat storage, center console organizer, BumperShellz color matched front bumper end caps. Tech12Volts/Taylor's Audio Sound System: Kenwood DMX1057XR head unit, Infinity Reference 5-ch amp, Hertz CK165L front, Hertz K170 rear, 2 JL Audio W0 10" subs in ported box behind seat, bass knob.
    Very nice. Those subs are on the expensive side but the reviews are about as good as you'll ever read.
  6. Feb 21, 2021 at 8:20 AM
    This is the way
    This is the way New Member
    Rthur
    looks good. using the killmat in the back,, i didnt take the panel off, i just went over the entire rear with killmat. i figured if i needed to get to the window motor or anything in there, i can just cut the mat.. thats a really nice box. good job..
  7. Feb 21, 2021 at 9:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    You shouldn't be using the SW level on the head unit to adjust on the fly. For the 1057, you should leave it at +1 to get to 5v on the output and leave it there. (There's a youtube vid on it).
    619Tundra and Desolate[OP] like this.
  8. Feb 21, 2021 at 5:48 PM
    Desolate
    After trying every which way to get the bass knob in a factory blank, there was just no doing it with this particular one from JBL. The circuit board behind it is bulky and will not fit. I did find the best hidden spot right next to the hood latch. This wasn't optimal for location but did provide a clean look and can easily reach while driving20210220_124032.jpg
    Also, for those of you wondering, I bought the grills for these subs and was able to get them in with the factory sound insulation mat. I did cut the factory threaded mounts for the JBL subwoofer. I am not sure if this provided more clearance but it did fit, just barely. In fact i think the seat bar is touching the grills but ultimately my kids won't ever be able to accidentally drop something and poke a hole in these subs. 20210220_104131.jpg
    PNWTundra2021, Rica25 and Danimal86 like this.
  9. Feb 22, 2021 at 7:29 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Where did you get the wire clamps for the power wire in the engine bay?
    Rica25 likes this.
  10. Feb 22, 2021 at 7:50 AM
    Desolate
    Home Depot.
    Rica25 and 619Tundra[QUOTED] like this.
  11. Mar 11, 2021 at 2:05 PM
    Ob1
    Ob1 New Member
    Sweet build!!! Question, can you take a closeup picture of your fuse mount and post for us? Been trying to build a fuse mount bracket for mine, and yours looks like a winner.
  12. Mar 11, 2021 at 2:17 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Good work, clean install. I have the same JL subs, love them!
  13. Mar 11, 2021 at 3:35 PM
    Freeezen
    Freeezen New Member
    I did something similar. I bought some ABS from Amazon, cut a thin strip, heated it and bent it to fit. I put a piece of foam under the mount so it wouldn't rattle.
  14. Mar 13, 2021 at 6:49 PM
    Desolate
    Thanks. I bought 1/4" ABS from Amazon then after i cut it to size with a table saw i placed it in a vice and used a heat gun to slowly heat up the plastic to get the 90 degree bend. I had to cut around the battery hold down a bit to make it work as well. 20210313_184330.jpg
  15. Mar 13, 2021 at 10:03 PM
    typerlegend
    typerlegend Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
    how are the subs?
    Rica25 likes this.
  16. Mar 13, 2021 at 10:52 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    How is that bench front seat? :thumbsup:
    Clean install..
    Looks great..
    Rica25 likes this.
  17. Mar 14, 2021 at 9:33 AM
    Desolate
    The subs are sound great. They sound clean and can get loud when you want them to.
    typerlegend[QUOTED] and Rica25 like this.
  18. Mar 14, 2021 at 10:07 AM
    Rica25
    Ricardo
    Tulare
    Did you tune it properly now?
  19. Mar 14, 2021 at 10:17 AM
    Desolate
    Rica25[QUOTED] likes this.
  20. Mar 14, 2021 at 2:16 PM
    Rica25
    Ricardo
    Tulare
    Oh ok. I went with the multimeter route. Oscilloscope is expensive for one time use. Going the multimeter way vs. by ear made a huge difference for me.
  21. Mar 21, 2021 at 9:51 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Anyone have a static hiss from their speakers after the kenwood 1037 install? I've swapped out RCAs and checked my ground and it's still present.
  22. Mar 21, 2021 at 10:06 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Most of the time static hiss happens because the amp's power cable is near rca or speaker wires.
    Rica25 likes this.
  23. Mar 21, 2021 at 10:11 AM
    619Tundra
    Your gains might be set too high.
  24. Mar 21, 2021 at 10:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    ^this
  25. Mar 21, 2021 at 10:46 AM
    I tore out the head unit and plugged in brand new RCAs that ran directly to the amp (no where near the power cable) and still have the same noise.
  26. Mar 21, 2021 at 10:46 AM
    the noise is present at all gain levels
  27. Mar 21, 2021 at 10:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    where did you connect the ground for your amp?
  28. Mar 21, 2021 at 11:24 AM
    I've narrowed down the issue to be with the head unit as I disconnected the amp and it is present in the dash speakers. The dash speakers are powered by the head unit.
  29. Mar 21, 2021 at 11:35 AM
    Danimal86
    Daniel
    Sacramento, CA
    I would disconnect the dash speakers if you are running component speakers with tweeters in the sail panels. Doesn't do much, and will have a volume difference.
    1lowlife likes this.
  30. Mar 21, 2021 at 11:52 AM
    The thing is this static noise is in all the speakers. I've only isolated it to a head unit issue so disconnecting the dash speakers won't fix the issue.
