Jerking on the highway
Discussion in '1st Gen Tundras (2000-2006)' started by jbl420, Mar 11, 2025.
  1. Mar 11, 2025 at 7:22 AM
    jbl420
    jbl420 [OP] New Member
    Jonathan
    2002 Tundra AC TRD SR5
    now that I have your attention (lol)
    My baby has been jerking and stuttering somewhere between 50 and 70.
    I just had it alligned, the transmission fluid is good, no slipping.
    The engine computer says 4 and 8 are misfiring. I am about to replace the plugs.
    Should I do anything else to help with the problem?
    1lowlife and Kung like this.
  2. Mar 11, 2025 at 7:23 AM
    Kung
    KG, VA
    Came here for the content...was disappointed. lol
  3. Mar 11, 2025 at 7:24 AM
    Superdave1.0
    Superdave1.0 New Member
    Dave
    LX470, 2025 Civic Si
    Swap coil packs around. See if the misfire follows where you put the potentially bad coil packs.
  4. Mar 11, 2025 at 7:28 AM
    Given you have a cylinder 8, I'm going to assume your engine is the 2UZ-FE and not the V6. Your profile doesn't say, so I'm grateful one of the misfires was on 7 or 8 so we don't need to ask ... (update your profile)
    When was the last time the timing belt was changed? How many years/miles ago? Bad timing (off by a tooth) will cause misfires at different cylinders of the same bank. Snapping the belt on your 2UZ can leave you replacing the engine (low interference engine).
    When was the last time the spark plugs were changed? How many years/miles ago?
    BEFORE you change the plugs, try swapping the coil packs between cylinders 8 and 6, and between 2 and 4. See if the codes change. This will tell you if the coil packs are the problem. If the codes change to cylinder 2 and 6 misfire, replace the coil packs.
    Remember: These trucks hate aftermarket coil packs. Denso brand. Don't buy from scAmazon or fleaBay, there are too many counterfeits in the supply chain, scAmazon's warehouses are rife with knockoff products. Purchase at Summit Racing or RockAuto. They have verified supply chains.
  5. Mar 11, 2025 at 8:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Also make sure the high voltage ground (the pad around the bolt hole) is free of oxidation and makes a good solid contact. This is often overlooked, and this is the reason #1 why coils going out.
    G_unit3000 and Jack McCarthy like this.
  6. Mar 11, 2025 at 8:33 AM
    SD Surfer
    Bruce
    So Cal
    Not at all what I thought this thread was gonna' be about. Called my wife over to read it fer nuthin!
  7. Mar 11, 2025 at 9:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Enjoy learning something new everyday about 1st Gen, so I was curious :monocle:
  8. Mar 11, 2025 at 9:34 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It's universal, not Toyota-specific.
    Also remove that bolt, pull the coil and inspect the pad. May just take a fine sandpaper and clean everything well, just in case.
  9. Mar 11, 2025 at 9:46 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
  10. Mar 11, 2025 at 6:04 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Ah, wasn't just me then!
    Kung[QUOTED] likes this.
  11. Mar 16, 2025 at 6:59 AM
    jbl420
    Jonathan
    I changed out my spark plugs, oil, and air filter.
    So far, its running a lot better. the plugs had no major damage from oil but a few of the gaps were valleys which was part of the problem. I did smell a faint touch of antifreeze on the old ones which has me worried.
    Thanks for all the uplifting comments.
    I'd say I got a happy ending
    SD Surfer, w666 and Jack McCarthy like this.
  12. Mar 16, 2025 at 7:14 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Happy endings are always best. Just be glad you got someone to help you out with your jerking problem.
    Fragman likes this.
