JBL premium system
Discussion in 'Audio & Video' started by Dfarva, Jun 4, 2021.
  1. Jun 4, 2021 at 6:58 PM
    Dfarva
    Dfarva [OP] New Member
    2021 green tundra
    Trd dual exhaust
    I’m about to install a amp and subwoofers in my 2021 Tundra and remove the stock one. My question is the current door speakers that are in the truck , are they hooked up to the amp that is installed in the truck? And when I disconnect the subwoofer from this amp will that amp give more power to the door speakers??
  2. Jun 4, 2021 at 7:00 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    One of the seemingly few benefits of getting old is that even the stock audio systems sound pretty good!
  3. Jun 4, 2021 at 7:01 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Not sure it matters but JBL or nonJBL?
  4. Jun 4, 2021 at 7:14 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    It seems like everyone bitches about the JBL stock systems, I have one and am pretty pleased with it. I don't need to feel my music, I just listen to it. :headbang:
    WillTunBlack20 likes this.
  5. Jun 4, 2021 at 7:19 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. Disconnecting the sub will not allocate more power to the doors. That is not how an amp functions when it comes to high and low channel outputs.
  6. Jun 4, 2021 at 7:42 PM
    Dfarva
    2021 green tundra
    Trd dual exhaust
    Thank you for answering my question
  7. Jun 4, 2021 at 7:48 PM
    Dfarva
    2021 green tundra
    Trd dual exhaust
    I happen to like the system to but for me personally it is not loud at all. If people are bitching then there is a reason. I’m just looking to improve on what I have.
    1lowlife likes this.
  8. Jun 4, 2021 at 8:15 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    What ? I can't hear you ! :cool:
    Nothing wrong with fixing your system up the way you like it ! That's what makes us all come here and check stuff out !!! I love modifying stuff
  9. Jun 4, 2021 at 9:02 PM
    Saltyhero13
    Not sure what stock system you have but its a common issue discussed on these forums. On the Tundra JBL system there is a feature that rolls the bass off at louder volumes; the speakers are substandard quality for a "premium" system.
    ToyoMafia likes this.
  10. Jun 5, 2021 at 4:34 AM
    Dfarva
    2021 green tundra
    Trd dual exhaust
    I have the JBL premium audio system the one that comes with the 1794. The subwoofer that comes with it is non existent. There is no bass really and when I turn the volume up to 60 it isn’t loud at all . I was expecting more
    1lowlife and camron1039 like this.
  11. Jun 5, 2021 at 5:12 AM
    Danman34
    Danman34 New Member
    Danny
    The system is mediocre at best. The systems internal processor automatically removes bass as you increase volume. You’re going to need to get a digital sound processor, like a Rockford DSR1 in order to remove the JBLs crappy processing unless you replace the entire system, ie, headunit, amps, highs, subs, etc.
    1lowlife, Saltyhero13 and 2010bigdog like this.
  12. Jun 5, 2021 at 5:14 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    You’ll end up replacing all 4 door speakers, choosing a single or dual subs & enclosure….(disabling the dash set tweets)
    adding a 5 channel amp and RF Mastero dsr1.
    Then you will have both volume & clean sound
    1lowlife, ToyoMafia and Saltyhero13 like this.
  13. Jun 5, 2021 at 5:15 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    the stock unit is garbage
  14. Jun 5, 2021 at 7:30 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    So like stated above disconnection of the sub will not change power/wattage to your doors. I would change the amp completely find yourself a good 5 Chan amplifier and yes you will need a dsr1 and mastero harness for the tundra. I would look to james at tech12volt to get you squared away with a replacement system. In installed one two days ago in a new lunar pro7DCA03B5-F738-4D1A-BDAD-B3393DD658C3.jpg
    1lowlife, Randydw and Saltyhero13 like this.
  15. Jun 5, 2021 at 7:59 AM
    Dfarva
    2021 green tundra
    Trd dual exhaust
    I went to a local shop and the owner wants to put 2 JL Audio 10s 10TW3 in the custom stealth box behind my seats. He is giving me a JL audio 600 watt one channel amp to push the box. He suggested to start with that and he is going to play around with stock speakers and the factory amp to make it sound better. I asked him about a 5 channel amp and he said you don’t want to hook up a 5 channel amp to push the stock door speakers. The amp would be to powerful for the stock speakers to handle. I’m already over 2 grand into it. Debating if I should throw down and spend another grand to change door speakers and amp ??
  16. Jun 5, 2021 at 8:00 AM
    Dfarva
    2021 green tundra
    Trd dual exhaust
    I will check out 12volt as well thanks
  17. Jun 5, 2021 at 8:03 AM
    ToyoMafia
    Magic carpet.
    A complete system from james including door speakers will be less then 2k FYI and you will not need to cut one wire in the truck. It can be swapped back to factory for resale in about 2 hours.
  18. Jun 5, 2021 at 8:05 AM
    Danman34
    Danman34 New Member
    Danny
    There is nothing he can do to “mess” with the stock speakers and amp. $2k for just subs and an amp is high as giraffe nuts.
  19. Jun 5, 2021 at 8:07 AM
    ToyoMafia
    Magic carpet.
    This is absolute truth right here. I personally would run from the deal.
  20. Jun 5, 2021 at 8:08 AM
    ToyoMafia
    Magic carpet.
    Actually there are all kind of things he can “mess” with but none of them will be good.
  21. Jun 5, 2021 at 8:13 AM
    Danman34
    Danman34 New Member
    Danny
    Aside from fooling with the bass and treble adjustments on the radio. There isn’t anything that is user adjustable on the amp. There are no gain, crossover, or any other adjustments that can be made.
  22. Jun 5, 2021 at 8:13 AM
    ToyoMafia
    Magic carpet.
    I’m trying to give you the best advice for your truck. Do yourself a favor and do some more research. I have seen many stealth boxes on this forum for sale because people have complaints about them and half ass’ng a stereo only takes you down a path of unhappiness and breaking the wallet out to try and fix it. There are members here that design amazing systems themselves for their truck they spend thousands doing it right and that is awesome but you are trying to get the most bang for your buck so
    Do yourself a favor and email james. Tell him you are a tundra member and listen to the advice he gives you.
    Saltyhero13 likes this.
  23. Jun 5, 2021 at 8:14 AM
    ToyoMafia
    Magic carpet.
    Well aware.
  24. Jun 5, 2021 at 8:22 AM
    ToyoMafia
    Magic carpet.
    But you forgot balance and fade! Lmao
  25. Jun 5, 2021 at 8:24 AM
    Danman34
    Danman34 New Member
    Danny
    Lol. Right.
  26. Jun 5, 2021 at 8:28 AM
    Saltyhero13
    I don't have anything to add. I strongly concur with Mafia and Dan. If you keep your head unit, temper your expectations. I am content with mine but you are limited in adjustments and it is a constraint to a good sound system. If you replace it the trade off is losing some control of vehicle settings, not sure how many the Maestro can reclaim. I think you'll loose the ability to change some chime settings etc, not sure about wifi or anything else.
    1lowlife and ToyoMafia like this.
  27. Jun 5, 2021 at 8:31 AM
    Danman34
    Danman34 New Member
    Danny
    The Maestro restores all controls. I lost not a single oem vehicle setting when I put in an aftermarket headunit.
  28. Jun 5, 2021 at 8:34 AM
    Saltyhero13
    All? I'm in. Head Unit is coming out.
  29. Jun 5, 2021 at 8:35 AM
    ToyoMafia
    Magic carpet.
    Lol
    Saltyhero13[QUOTED] likes this.
  30. Jun 5, 2021 at 8:39 AM
    Danman34
    Danman34 New Member
    Danny
    Yep. I still have access to everything. Lights. Sensitivity. Time delay after key out. Door lock sound. Drl control. Lock and unlock settings, etc etc.
