JBA Longtube Install
Discussion in 'Performance and Tuning' started by Sting Ray, Feb 8, 2018.
  1. Feb 8, 2018 at 6:36 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Installing these this weekend. Gonna take some pics and such along the way. JBA Longtubes in silver ceramic.
  2. Feb 8, 2018 at 6:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Got everything installed. A few tips for anyone that's interested.
    1. If you aren't seriously mechanically inclined, skilled at installing nuts on studs you can't see or touch then pay someone to do this for you. I work on multi million dollar fighter aircraft and am used to working in tight spaces but this is beyond that...
    2. Tools I used the most: 12mm deep well socket, 12mm shallow socket, 12mm medium well socket, extensions, universals, 12mm gear wrench, 12mm box end wrenches (small and regular size), 10mm deep well socket, 14mm deep well socket, magnet.
    3. Do the passenger side first it's a pain in the ass because it's a very tight fit sliding the header into place. I hammered my cab so the Air tube would clear. Then once in place the Air tube would again get hung up on the air tube mount studs.
    4. Drivers side was easier as the header slips right into place, but the top middle nut is a pain in the ass.
    5. I had to cut my drivers side mid pipe out of the truck. I tried for two hours to remove it to the front, to the back. My truck's not lifted and on stock tires so if you had more ground clearance you might be able to get it out.
    6. Use a lift if you can, it will save your back.
    7. The O2 sensors were also a pain. 3 of the 4 aren't long enough to reach the ports so you have to unlug them, unclip the plug from the little backet, install them into the ports, reconnect, and zip the the wire back up.
    8. Make sure you have a big Allen wrench for the plugs that go in the headers.
    9. Don't forget to unbolt the dip stick and make sure to pull this out of the way while you are trying to get the passenger side header lined up.
    10. When you install the bolt for the dipstick be sure to recheck the other end that goes into the motor to ensure it didn't pop out. When I installed the header it bent the dipstick tube a bit so I couldn't have it popped into the engine and bolted up top at the same time and thus caused an oil leak when I would go around a left hand turn and all the oil slouched to the right side. Wouldn't leak just running in the drive way or even driving , only leaked when turning. Had to bed it back, pop it in the motor, bolt it up, and then recheck to see it didn't pop out.
    This pic is of the passenger side mid pipe to manifold connect. You will need to us 14mm deep well for these. They were super tight, I had to use a big box end wrench on the end of the ratchet handle for extra leverage.IMG_6481.jpg
  3. Feb 8, 2018 at 6:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Reserved again
    dirtydeeds likes this.
  4. Feb 8, 2018 at 6:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    And again
  5. Feb 8, 2018 at 6:37 PM
    Cfincke
    San Antonio
    What are you doing for mid pipes?
    Black Wolf, dirtydeeds and trayday like this.
  6. Feb 8, 2018 at 7:06 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  7. Feb 8, 2018 at 7:12 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    For the time being I am installing some loaner straight pipes that Keith @dirtydeeds made me. I'll be sending him my cats so he can make some custom mid pipes with them. So I'll be rolling with a CEL for a minute.
  8. Feb 8, 2018 at 7:19 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Looking fwd to the install, this will most likely be my next mod.
    1UPPER and GNTundra like this.
  9. Feb 8, 2018 at 9:24 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Following so I can help if needed.
  10. Feb 9, 2018 at 12:28 AM
    Chefjjdecker
    Chefjjdecker New Member
    I have my stock midpipes and cats for FREE for local pickup only in tucson if anyone wants them.
    trdprobped17 likes this.
  11. Feb 9, 2018 at 3:59 AM
    Cfincke
    San Antonio
    Good deal! That is what I want to do as well when I can eventually afford the headers and mid pipes. Cannot have the truck down for more than a weekend.
    Sting Ray[QUOTED][OP] likes this.
  12. Feb 9, 2018 at 5:35 AM
    fuguchan
    fuguchan New Member
    Jeff
    St. Mary's County, MD
    2018 Tundra 1794 Edition Smoked Mesquite
    ARE-Z Cap, Bed Rugs, Husky Mats
    :popcorn:These JBA long tube headers and other similar articles are making me want to spend some money this summer. Along with the 8” Bam exhaust. What are the loaner straight pipes like?
  13. Feb 9, 2018 at 5:43 AM
    Going to be so cool Ray!
  14. Feb 9, 2018 at 5:49 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    The straight pipes are just straight pipes nothing special. Just temporary until the others get done. I have the 8" system and love it!
    trdprobped17 and dirtydeeds like this.
  15. Feb 9, 2018 at 5:49 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yeah I am so tempted to just call off work and go do it right now, lol.
  16. Feb 9, 2018 at 6:56 AM
    Munk
    Munk Vol For Life
    Mickey
    Bristol, Tennessee
    2017 Black SR5 Tundra Crew Max
    3/2 Lift
  17. Feb 9, 2018 at 6:59 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  18. Feb 9, 2018 at 7:03 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Oh yeah gotta see this.
    Sting Ray[OP] and dirtydeeds like this.
  19. Feb 9, 2018 at 7:40 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Get a buddy to help you. It's a lot easier if someone feeds the tubes from the bottom and holds it while you bolt it up. Especially on the passenger side, that's a tight fit!
  20. Feb 9, 2018 at 8:22 AM
    dirtydeeds
    Keith
    USA
  21. Feb 9, 2018 at 8:35 AM
    Danimal86
    Daniel
    Sacramento, CA
  22. Feb 9, 2018 at 10:12 AM
    dirtydeeds
    Keith
    USA
    That’s when you run 3” dual exhaust after the headers.
  23. Feb 9, 2018 at 10:19 AM
    Danimal86
    Daniel
    Sacramento, CA
    Is that the "race setup" or are all your exhausts 3"ers? trd dual a 3"?
    Sting Ray[OP] likes this.
  24. Feb 9, 2018 at 10:56 AM
    dirtydeeds
    Keith
    USA
    We can make em all any diameter. But I size the diameter of the system according to what works best for the end users goals.
    In the case of a Trd rep, it can be made 3” but then you can’t use Trd tailpipes. They’re 2.5”. Now if you wanted a Trd rep dumped in 3” we can do that.
    Know what I mean?
  25. Feb 10, 2018 at 8:10 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Done! 14 hrs...Inwill never ever ever ever do that again....but you know what? It's sounds and feels BAD ASSSSS!!!!! I'll get some Pics and video up tomorrow maybe.
  26. Feb 10, 2018 at 8:19 PM
    TheBeast The Beach
    man that's gonna unleash the 5.7L
  27. Feb 10, 2018 at 10:06 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Are the JBA's a straight bolt in?
  28. Feb 10, 2018 at 10:29 PM
    Wow!! You earned that power! Bang for your buck, I don’t think there is a better mod for that much performance.
  29. Feb 11, 2018 at 3:42 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Since the headers come farther back then the stock manifold you have to also get new mid pipes. I'll be having Keith at dirtydeeds build me some custom mid pipes and weld all 4 of my cats into them. For now, I just have catless midpipes.
    trdprobped17, aperezsh and ColoradoTJ like this.
  30. Feb 11, 2018 at 4:59 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    @Sting Ray are you supercharged ot NA? I've considered headers to get a few more ponies but wondered if it would pay dividends on a non SC'd motor?
    dirtydeeds and Sting Ray[OP] like this.
