JBA Headers
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Apr 11, 2021.
  1. Apr 11, 2021 at 11:04 AM
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
  2. Apr 11, 2021 at 3:34 PM
    Barabajackel
    Barabajackel New Member
    Pittsburgh
    06 double cab
    You going to die the whole exhaust or just long tubes
    FlightSimGuy[OP] likes this.
  3. Apr 11, 2021 at 3:38 PM
    FlightSimGuy
    Planning on just the long tubes right now. Doing some other maintenance items so I might do the whole exhaust once I can budget it.
  4. Apr 11, 2021 at 3:47 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If your trying to do long tubes it’s not just a straight swap, short tubes would be a direct swap
    des2mtn, Darkness, Voss and 2 others like this.
  5. Apr 11, 2021 at 4:01 PM
    FlightSimGuy
    Oh, good to know. I remember seeing the short tubes. Any advantage to going with long tubes/full exhaust replacement?
  6. Apr 11, 2021 at 4:19 PM
    FlightSimGuy
  7. Apr 11, 2021 at 4:58 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Long tubes give the best performance gains, but require either new or modified mid pipes. I've heard tons of conflicting info about shorties. Some they lose low end, some say there is no difference, some say that you gain low-mid end. Personally, my truck feels more responsive with my OBX shorties, but that was probably more due to the multiple exhaust leaks on my old manifolds. If you go shorties, use remflex gaskets on the collector pipe, and percys or OEM gaskets on the flange.
  8. Apr 11, 2021 at 5:04 PM
    FlightSimGuy
    Hmm. Thanks for the explanation. If I did long tubes any recommendations for mid pipes? Also kinda curious what a completely new exhaust would look like.
    Black Wolf likes this.
  9. Apr 11, 2021 at 5:06 PM
  10. Apr 11, 2021 at 5:07 PM
    See post #9. Call Keith....vendor here that will get you set up. Easy peasy
  11. Apr 11, 2021 at 5:10 PM
    FlightSimGuy
    Was just searching some more on here and saw his posts. Thanks guys, I'll call him!
  12. Apr 11, 2021 at 5:11 PM
    Nice guy and will not jerk your chain....
  13. Apr 11, 2021 at 5:22 PM
    Ask Keith about his upgraded fuel injectors for the 1st gen...
  14. Apr 11, 2021 at 5:27 PM
    FrenchToasty
    Mo
    Bone stock
    Quit yellin!
  15. Apr 11, 2021 at 5:33 PM
    Not using CAP's. Just doing my part......while bbqing some Philippine Cebu style longanisa while watching my grandson play on his tree fort and chewing gum at the same time...
  16. Apr 11, 2021 at 5:35 PM
    FrenchToasty
    Mo
    Bone stock
    Can you explain this longanisa? I read lasagna First skim thru
    Darkness and Black Wolf[QUOTED] like this.
  17. Apr 11, 2021 at 5:38 PM
    Go live in the Philippines for 3 years like I did or go find a decent Philipino restaurant near you...don't want to further derail....
  18. Apr 11, 2021 at 5:51 PM
    FlightSimGuy
    Why haven't I been on here more? :rofl:
    Darkness and Black Wolf like this.
  19. Apr 11, 2021 at 5:53 PM
    You have a good idea now why you should. Ha!
  20. Apr 11, 2021 at 5:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Do some research, it isn't exactly a direct bolt on,
    Its a tasty kind of sausage. Has a sweetness to it. Usually skinnier but those look really good.
  21. Apr 11, 2021 at 6:04 PM
    Not to derail further, but size of longanisa depends on what province and it can be quite spicey. Cebu style is quite small and short actually. In Ilocos Norte the longanisa is much bigger. I used to buy it in Baatac at the meat market up to 2ft long because stuffed in actual pig gut. Take it home and have grill heaven.....
    Voss and Darkness[QUOTED] like this.
  22. Apr 11, 2021 at 6:06 PM
    I thought Keith had the 1st gen headers/exhaust pretty much plug and go play?
  23. Apr 11, 2021 at 6:37 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is a lot of add on needed for vvt-i motors. He sells a block off plate for them which needs an extra set of gaskets. Then you need to extend the wiring harness for the O2 sensors and have the cats modified to weld on the v band clamps. From the cats back you have to redo the y pipe or just go custom.
  24. Apr 11, 2021 at 6:44 PM
    FlightSimGuy
    Dammit. You guys are going to have me spending MORE money on my truck! :annoyed::rofl:
    And how did we go from headers to sausages?! o_O
  25. Apr 11, 2021 at 6:58 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're required to install headers!
    Black Wolf and FrenchToasty like this.
  26. Apr 11, 2021 at 7:00 PM
    FlightSimGuy
    Oh. I thought that was beer.
    Voss, Darkness[QUOTED] and Black Wolf like this.
  27. Apr 11, 2021 at 7:04 PM
    Uggh...I guess I should stick with 07 issues and up!
    Well...there is that too.....
    Darkness[QUOTED] likes this.
  28. Apr 11, 2021 at 7:08 PM
    Darkness will set you straight! I apparently need to stick with grilling sausages...ha!
    Darkness likes this.
  29. Apr 11, 2021 at 7:10 PM
    come on...it can't hurt. We have to eat too:thumbsup:
