Jacking your tundra up
Discussion in '2.5 Gen Tundras (2014-2021)' started by havasuTRD, Jul 5, 2020.
  1. Jul 5, 2020 at 4:32 PM
    havasuTRD
    havasuTRD [OP] New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    I’m preparing for a family vacation up to Utah and was wondering since I have the black tubular step bars and they block the frame, is it safe to use those for a jack point if I had to change a flat tire? Or Do you guys recommend another place? Thx
    hopefully don’t have to worry but I’m trying to think ahead
  2. Jul 5, 2020 at 4:36 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nope, tube steps won't work generally speaking. Sliders will 'cause they're built (or should be) to support the weight of the truck. Tube steps are only built to support a couple hundred pounds.
    dcsleeper408, joonbug and GodlessPro like this.
  3. Jul 5, 2020 at 4:36 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I suggest anywhere on the frame. I would not use the tubes unless you had no other choice.
  4. Jul 5, 2020 at 4:37 PM
    havasuTRD
    Brett
    Ok, I figured as much. Thx guys
  5. Jul 5, 2020 at 4:42 PM
    Use the frame.
