Jacking up the rear
Discussion in 'General Tundra Discussion' started by marbleville, Aug 24, 2019.
  1. Aug 24, 2019 at 8:54 PM
    marbleville
    marbleville [OP] Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    My son and I are in disagreement on whether or not it is okay to jack my Tundra from the rear differential housing. With jack stands handy and wheels chocked, I say it is okay to jack at the differential if using a good 3-ton floor jack, with plans to place stands on either side of the axle. My son says no, and that I should either jack at either side of the diff on the axle, or at the pinch points located fore and aft of the tires.
    What is the correct placement point when jacking the rear end?
    YardBird likes this.
  2. Aug 24, 2019 at 8:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve been lifting from the pumpkin my whole life and never had an issue.
  3. Aug 24, 2019 at 9:06 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    #metoo
  4. Aug 24, 2019 at 9:15 PM
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    htw_hawaii, 15whtrd and Pudge[QUOTED] like this.
  5. Aug 24, 2019 at 9:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    floor jack is at the diff, because it will not slip off if the floor jack wheel don't move.
    the cup on the floor jack will slip off the axle, and it will damage the sheet metal if jack on pinch point.
    If you have a sway bar then you have to jack on the diff or the frame
    marbleville[OP] likes this.
  6. Aug 24, 2019 at 9:19 PM
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    i think the diff lift is fine but what do i know?! i'm not even sure where i learned to do that...
    Kerch71, marbleville[OP] and 15whtrd like this.
  7. Aug 24, 2019 at 10:40 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    What I want to know is since when is the father ever wrong? Even if the son is right he is still the son there fore everything you say is void because I'm your father and what I say goes.. needless to say I have never won an argument with my father..
  8. Aug 24, 2019 at 11:34 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    My 85 year old mechanic buddy has been lifting vehicles with a floor jack beneath the "Pumpkin" all his life ~ I learned this trick from him, actually.
    I know we're talking apples and oranges here ~ see if you can stay with me on this one.
    I had an antique 1965 Ford Falcon ~ I always jacked the rear end up the same way ~ floor jack under the pumpkin.
    Then the axle housing developed a leak ~ the gear oil was getting out of a hairline crack and making a mess.
    I took the whole third member out of the housing, blocked off the opening with a piece of sheet metal and welded up the crack in the housing to stop the leak.
    Reinstalled the third member, axles and put the vehicle back on the road without issue. Worked like a champ ~ no more leak.
    That was the very last time I'll ever jack up the back end of a rear wheel drive vehicle in this manner.
    I'm not about to go through this with another vehicle of mine ~ Ever !
    Your Mileage May Vary . . . :)
  9. Aug 24, 2019 at 11:43 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I always lift at the rear pumpkin
    YardBird and marbleville[OP] like this.
