Jack under pumpkin or not?
Discussion in 'General Tundra Discussion' started by Eaganite, Oct 20, 2021.
  1. Oct 20, 2021 at 5:34 AM
    Eaganite
    Eaganite [OP] New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    So it's time for tire rotation, and to make my life easier i would like to jack up the rear of the truck under the differential then place jack stands on each side of the axel so as to support the rear off the ground.
    I'm not sure if this is a safe practice. I am nervous about jacking this way although a friend of mine always uses this method on his truck. So I decided the post the question to this great knowledge base. Thanks in advance!
  2. Oct 20, 2021 at 5:35 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Should not be an issue. I have done it this way for many years and have never had any issues. That's how the tire store does it when there is no rack available.
  3. Oct 20, 2021 at 5:38 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    If it’s wrong I’ve never known any better.
  4. Oct 20, 2021 at 5:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No problem at all!
  5. Oct 20, 2021 at 6:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    yeet that skeet
  6. Oct 20, 2021 at 6:36 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Done it more times than I can count. I always use a piece of wood between the Jack and truck anyway.
  7. Oct 20, 2021 at 6:39 AM
    Taco-Spike
    Two Trucks
    I've never done it personally but seen tons of people never have a problem. I'm the driver side then passenger side guy though. If I did do it, I wouldn't be worried about anything though.
  8. Oct 20, 2021 at 6:42 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    My floor jack has a nice rubber pad that let's the diff settle down into it, seems more secure. I've always jacked at the diff, no pad, just used a piece of 2x6. Never an issue.
  9. Oct 20, 2021 at 7:34 AM
    2mchfun
    Just have them balanced and rotated at a shop. They should be balanced anyway for a top notch job.
  10. Oct 20, 2021 at 7:44 AM
    Eaganite
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I can't see any reason to spend money needlessly, there's no noticeable shimmy at any speed so balance isn't an issue. After new tire replacement when I have free rotate and balance with the purchase, that will be the norm.
  11. Oct 20, 2021 at 7:48 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Very common practice, I would not worry about it.
