I've got a 2000 SR5, 4.7, 4WD. Recently when I select 4WD, nothing happens.
Discussion in '1st Gen Tundras (2000-2006)' started by noyfub, Sep 12, 2022.
  1. Sep 12, 2022 at 8:07 AM
    noyfub
    noyfub [OP] New Member
    2000 Tundra. 4.7, 4WD
    The Light doesn't flash. There is no sound coming from the Transfer case. The fuses are good and power is getting to the Center integration panel and the 4WD ECU. The pin on the cable going to the ECU seems to change state when the button is pushed. I'm thinking the ECU is bad. Any Ideas?
  2. Sep 12, 2022 at 3:10 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Have you checked the actuator at the transfer case?
  3. Sep 15, 2022 at 11:39 AM
    noyfub
    Yes it works when I bypass the ECU. Haven't tried the front Actuator yet.
  4. Sep 15, 2022 at 11:41 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    When was the last time it was used?
  5. Sep 15, 2022 at 11:50 AM
    shifty` All my rowdy friends have settled down
    I'm going to ask the stupid question because you never know until you ask.
    You're hitting the 4HI button, right?
    Nothing flashes when you press the button?
  6. Sep 19, 2022 at 12:27 PM
    irhunter
    irhunter New Member
    '03 Tundra V8, AT, 4x4, extra cab
    FWIW.
    The FSM suggests moving the truck back and forth...if you get no 4x4 light after pushing the button.
    Roy
  7. Oct 11, 2022 at 7:38 AM
    noyfub
    Right, I'm pushing the 4 Hi button. I've narrowed it down to the ECU. I'm Getting the input to the ECU when I push the button, but no output.
  8. Oct 11, 2022 at 7:58 AM
    Water intrusion at the ECU?
  9. Oct 11, 2022 at 8:06 AM
    irhunter
    irhunter New Member
    Do you have the 4x4 ecu pin specs?
  10. Oct 11, 2022 at 8:06 AM
    noyfub
    I don't think so.
  11. Oct 11, 2022 at 8:07 AM
    noyfub
    I do have the pin-out for the ECU.
  12. Oct 11, 2022 at 8:29 AM
    irhunter
    irhunter New Member
    In case someone needs them.
    bmf4069, vtl and shifty` like this.
  13. Oct 11, 2022 at 1:45 PM
    noyfub
    Replaced the ECU and I have 4WD again.
    bmf4069, vtl and irhunter like this.
  14. Oct 11, 2022 at 1:51 PM
    Great to hear! Any obvious reason for failure?
    noyfub[QUOTED][OP] likes this.
  15. Oct 11, 2022 at 3:10 PM
    irhunter
    irhunter New Member
    And, did you buy new, used, or what?
  16. Oct 11, 2022 at 7:09 PM
    noyfub
    No obvious cause. Nothing visible on the circuit board. It was new. I didn't even think of trying to find used, probably should have tried. I paid $357 for it at Toyotapartsdeal.com.
    irhunter likes this.
  17. Oct 11, 2022 at 7:23 PM
    $357 well spent if the 4wd works again.
    noyfub[QUOTED][OP] and irhunter like this.
  18. Oct 11, 2022 at 7:47 PM
    Welp, won't be replacing that for another 20 years. :rofl:
    Good solve, OP
  19. Oct 12, 2022 at 4:49 AM
    irhunter
    irhunter New Member
    Thanks for the wrap-up.
    There are a bunch of things I like about my Tundra...none of those things are connected to the 4x4 control system.
    Roy
    noyfub[QUOTED][OP] and shifty` like this.
