Ive been putting 87 in but google says thats bad
Discussion in '1st Gen Tundras (2000-2006)' started by 2000Strong, Aug 18, 2019.
  1. Aug 18, 2019 at 10:14 PM
    2000Strong
    2000Strong [OP] Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    upload_2019-8-18_22-14-14.jpgWonder what octane it is ahaha
    OR18TRD and Darkness like this.
  2. Aug 19, 2019 at 12:50 AM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Ethanol free gas is the better choice for all gas motors.
    Deuxlatch and Lake.Life24 like this.
  3. Aug 19, 2019 at 4:22 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Google is bad.
  4. Aug 19, 2019 at 5:00 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Pump gas nowadays has only a 2 week shelf life before it starts breaking down due to the ethanol in it. This is why it's no good after it's been stored unless you use an additive like StarTron. In the case of your Tundra, if it has over 100k mi I would use a higher octane to keep the valves from clattering. I run the highest octane possible at all times because I'm supercharged. I run mid-grade in the wife's 4 runner and never had a problem. It also helps to run a top tier gas from places like Exxon, Chevron or Shell because they have additives to keep their fuel clean. It's like if you ate at McDonalds every meal every day. Sure it would sustain life but you sure wouldn't feel your best and after a it would cause massive problems.
  5. Aug 19, 2019 at 5:07 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    If pump gas started to break down in 2 weeks without an additive, why have I not had a single issue with my boat (new in 05') that is stored for months at a time?
  6. Aug 19, 2019 at 5:39 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I talked to a coworker when I was in Yuma. I'll try to get ahold of him and find out his mixture.
    He was mixing E85 and 91 in his 2003 Tacoma and getting great results.
    He said he tried it in his wife 06 Sequia but (all the lights came on) on the dash. Once he ran it through and put regular gas in it the Sequia was fine.
    So I'm wondering if putting a Gal or two of E85 in and then fill up with 91 would be ok?
  7. Aug 19, 2019 at 6:00 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    You try it first and we'll watch:popcorn::popcorn:
  8. Aug 19, 2019 at 6:06 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I would trust a manufacturer manual over what google says. For the most part it says for Toyota V8s 87 or higher.
    because_wumbo-truck likes this.
  9. Aug 19, 2019 at 6:10 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    LOL right? Im not in a hurry to try it. lol
  10. Aug 19, 2019 at 6:13 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Need more info. Is the pump at the dock? Typically those are ethanol free for marine use. Is your engine 2 or 4 stroke? Typically 2 strokes have smaller carb jets that get clogged with enzymes when stored but a 4 stroke usually has bigger carb jets. Do you use any additives like Sta-Bil or StarTron in your fuel, especially before you store your boat? I'm not gonna get into a pissing contest with you, I'm just going off personal experience with small engines and fuel analysis from a coworker here at Shell.
  11. Aug 19, 2019 at 6:33 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    This and encyclopedia Britannia!
  12. Aug 19, 2019 at 7:06 AM
    Rex Kramer
    Georgia
  13. Aug 19, 2019 at 7:27 AM
    Casper421
    In the woods
    06 DC
    00-06 manual: 87 or higher.
  14. Aug 19, 2019 at 7:32 AM
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    I don't know, but consider yourself lucky. I can confirm because I have personally seen phase separation in ethanol blend fuel that was left to sit in my boat's gas tank. It caused all sorts of problems and was very expensive to get cleaned up. Just go to a small engine repair shop - the type that services lawn mowers and weed eaters, and ask them about ethanol fuel. Well, they may actually give it a glowing recommendation because it's keeping most of them in business.
    Ericsopa and Deuxlatch like this.
  15. Aug 19, 2019 at 12:15 PM
    02goes
    02goes New Member
    I drink, and sometimes the dog, but never the trk. The motor gets nasty and doesn't get good mpg when it's all tanked up on the stuff. :drunk:
    Ethanol
    fuel is ethyl alcohol, the same type of alcohol found in alcoholic beverages, used as fuel. It's a water sponge; Ethanol gasoline will absorb water and can absorb 50 times more water than conventional non-alcohol gasoline. Phase separation occurs in E10 gas. So says Google.
    Sunnier likes this.
  16. Aug 19, 2019 at 12:31 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Not marina gas, mostly from a chevron 'in town', fuel injected 4 stroke, never any additives. Never any issues. Boat gets stored with whatever amount of fuel that was left that trip, usually less than 1/4 tank.
    Deuxlatch[QUOTED] likes this.
  17. Aug 19, 2019 at 12:41 PM
    02goes
    02goes New Member
    Outboard or inboard engine?
  18. Aug 19, 2019 at 1:01 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    What's the manual say about oil change intervals? Iirc my 99 taco manual said every 7500 miles.
  19. Aug 19, 2019 at 1:07 PM
    Casper421
    In the woods
    06 DC
  20. Aug 19, 2019 at 1:10 PM
    because_wumbo-truck
    Jon
    Houston, Texas
  21. Aug 19, 2019 at 1:26 PM
    Casper421
    In the woods
    06 DC
  22. Aug 19, 2019 at 1:30 PM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Well there you go. Gotta love those 4strokes.
  23. Aug 19, 2019 at 2:18 PM
    Aerindel
    Aerindel New Member
    Montana
    Because you're not a wacko. I'm.....a certain kind of person.....who among other things stores large amounts of gasoline....I rotate it out after a year. I could keep it for 2-3 years if I wanted to put gas preservative in it until I need to do that, I just use a yearly rotation. No problems, and yeah its 87, with ethanol.
    Nm6300'asl[QUOTED] likes this.
  24. Aug 19, 2019 at 2:38 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Outboard, yamaha 115, performance has not changed thru life of engine via tach and gps mph thruout its life. Modern fuel is pretty good at storage.
  25. Aug 19, 2019 at 4:00 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    I ran Maverik 87 ethanol free for 5-6 tanks when I first got my truck, and noticed it had less power than the ethanol stuff. If you have a FFV, just run 87 regular and save some dough. Or get a diesel.
  26. Aug 20, 2019 at 6:17 PM
    2000Strong
    Benjamin
    Washington
    My truck was parked when we pcsed to Hawaii we put fuel stabilizer in and disconnected the battery and when we got back to it 4 years later minus a wasp infestation and flat tires it started right up.
    Luckydog likes this.
  27. Aug 20, 2019 at 6:24 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    BUT... you had a delicious bounty of wasp honey!
  28. Aug 20, 2019 at 6:34 PM
    2000Strong
    Benjamin
    Washington
    And a lot of stings!
  29. Nov 29, 2019 at 9:43 AM
    Professional Hand Model
    Hand Protectors
    Stick with 87 as its what the engine was designed to run. The knock sensors and ECU adjust to correct slight problems. If they do not adjust your problem, then you have another problem like bad maintenance or worn parts.
    Rex Kramer likes this.
  30. Nov 29, 2019 at 10:21 AM
    Hand Protectors
    @bmf4069 we have a repeat offender that can’t help himself.
    bmf4069 likes this.
