Its squeaking and clunking, stock 2011 4wd Tundra with 70k miles . . . .
Discussion in 'Suspension' started by Aron9000, Jan 20, 2020.
  1. Jan 20, 2020 at 10:31 PM
    Aron9000
    Aron9000 [OP] New Member
    Aaron
    To get into it a bit more, all these noises are occurring at lowish speeds, the clunking noise is only when you turn the wheel at less than 15mph, and you can only hear it with the radio off. Still it sounds like shite.
    The squeaking suspension noise is a bit more prevalent. You can hear it when you hit a hard bump, 10mph, 20mph, 30mph. Its a kind of squeak/rattle that reverberates through the chassis/body at speeds under 50mphish. FYI I can jump up and down on tube step at the drivers side door and produce that same damn squeak.
    FYI truck is on stock suspension, stock wheels/tires.
    Any suggestions on fixing it before I take it to my mechanic would be much appreciated.
  2. Jan 21, 2020 at 2:25 AM
    TundraNationalist
    TundraNationalist New Member
    2008 BASED CrewMax 4.7L
    Check your suspension joints might need some grease. Also check your bushings to see if any are failing. Probably better to have a buddy come help you pinpoint the sound while you jump up and down to recreate it. Best of luck.
    jeremyd likes this.
  3. Jan 21, 2020 at 9:42 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Front lower ball joint!
    I would bet $ on it
  4. Jan 21, 2020 at 10:24 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    A lot can happen in 9 years outside...
  5. Jan 21, 2020 at 11:54 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Had a car that did this. replaced struts and then lower ball joint. Ball joint fixed it (also had universals on an old ford that squeaked at low speeds, replaced the rear shock, didn't fix it was the drive shaft).
    I'm getting lower ball joints as well. but a buddy listening while you jump would be a good place to start.
