It happened again.
Discussion in '2nd Gen Tundras (2007-2013)' started by biglakebubba, Jun 19, 2025.
  1. Jun 19, 2025 at 5:07 PM
    biglakebubba
    biglakebubba [OP] New Member
    Bill
    2008 tundra 5.7l ext can.
    No
    Years ago (10) I did some thing to my 08 Tundra to cause the starter to run on and the engine to “no start” until I turned the ign switch back to the off position. No start but cranking. In other words, starter continues to crank in on position.
    Before this happened, I was troubleshooting trailer lights no power.
    Any helping me remember what I did and what I need to do appreciated. Bill
  2. Jun 19, 2025 at 6:47 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Start checking fuses
    Tundras have an auto crank till start thing. The starter turns until the engine starts if the engine doesn't fire you have to turn key off to stop starter
    biglakebubba[OP] likes this.
  3. Jun 20, 2025 at 7:04 PM
    biglakebubba
    Bill
    No
    I’m on it friend. Will let you know what creature comes along. Thanks, Bill
  4. Jun 24, 2025 at 9:28 AM
    ScreenSavers
    ScreenSavers ‘07 Crewmax
    Luke
    Savannah GA
    2007 Tundra Crewmax 5.7
    This will also happen if a non chip key is used to try to start the truck. If you use a key not recognized by the immobilizer it will crank but not start. It's a security system. Just a thought in case you tried a spare key or something...
  5. Jun 24, 2025 at 9:52 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    start by disconnecting the battery for about 5 minutes. reconnect and try again.
