It costs what to recharge your A/C!!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anohibian, Jun 15, 2021.
  1. Jun 15, 2021 at 1:23 PM
    Anohibian
    Anohibian [OP] New Member
    Anchorage, AK
    2018 Inferno Crewmax
    So the a/c in the 2018 stopped blowing cold air this year. It seemed a little premature to need a recharge without having a bigger issue with the system, so I took it in today to get looked at. The service tech check the compressor, a little stiff to turn, but said that could happen if it is low on the wonderful yf1234 coolant. Next he hooked the system up to my truck for a pressure check. Came back as solid, no leaks. BUT ABSOLUTELY ZERO COOLANT. So somehow I have a sealed system but lost all the refrigerant. Next step is to pressurize with refrigerant and use a sniffer to check for a leak. Cost is $1100 to fully recharge the system. $1100 to charge a system and possibility have it leak right back out. No other non dealer car care places around me will touch the new refrigerant. I really want to know how I loose everything in the system but don’t show a leak?
  2. Jun 15, 2021 at 1:48 PM
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    If he's using a little portable ac recover/charge unit to test, those things are junk for pressure testing. If you hook up with some nitrogen and put a charge into the system, there will be a leak somewhere. Like you said, it doesn't disappear on its own.
    If he did use nitrogen to pressure check it, and found nothing, then that is highly strange and I wish you good luck
    Shamrock92, Black Wolf and WBW like this.
  3. Jun 15, 2021 at 1:49 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    So our Tundras no longer use the R134a freon substitute? Anyway, it does seem odd that there are supposedly no leaks, but it’s completely empty. I’m no a/c expert, though, so I’m no help. Curious to know what you find out, though.
    And yeah, $1100 sounds high to recharge. I think they have to pressurize it and then vacuum it all out, including whatever water vapor may be trapped in the system before the refill, at least that’s what I remember in the past with the R134a stuff.
  4. Jun 15, 2021 at 1:56 PM
    Anohibian
    Anchorage, AK
    R134 is being phased out for yf1234. Supposed to be more environmentally friendly, but is 10 to 12 times the cost. Not sure what type of system the hooked it up to. They spent three hours checking the system. They won’t have the refrigerant until the 1st of July, so I’ll update then. They did have a bunch of CPO 2021 Tundras on the lot, maybe just switch out the truck.
    Black Wolf and equin like this.
  5. Jun 15, 2021 at 2:00 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    If there are no leaks, why does it need refrigerant? That doesn't make sense.
  6. Jun 15, 2021 at 2:03 PM
    2mchfun
    A little refrigerant is actually lost over time but not a short time like your case. Almost can promise you have a leak in the system or a technician who is misleading. Maybe both.
  7. Jun 15, 2021 at 2:06 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    My previous neighbor made his career in HVAC. One of the first things he told me was "If an HVAC guy tells you he just needs to recharge the system, ask him to show you where the leak was and to explain how he fixed the leak. If he can't or won't do that, he's trying to screw you. If your system was working fine, and all of a sudden the solution is you need refrigerant, there's either a leak or he's full of shit."
  8. Jun 15, 2021 at 2:06 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    $1100 sounds like highway robbery. A R-1234yf recharge should cost around $200 in refrigerant, that means you're paying $900 in labor. I'd find a new AC guy.
  9. Jun 15, 2021 at 2:07 PM
    HARPER306
    SK, Canada
    Yup when my 2015 ram a/c stopped working, there was a shortage of 1234yf as well. Luckily I snuck in under warranty, but they said it would have been about $900
  10. Jun 15, 2021 at 2:13 PM
    Anohibian
    Anchorage, AK
    I tried to find a new one. But around me only the dealers work with the new refrigerant.
    There are reports of the new systems loosing refrigerant in cold weather, and here in Alaska we have been known to have a chilly day here or there. My truck lives outside and has done a few weeks these past two years when the warmest temp was -20F. So who knows. Until they pressurize it instead of drawing a vacuum, may not be able to detect the leak. I’m just having a real hard time with the cost. If it wasn’t for my kids I fall back to 3-60 AC.
    Randy Morton[QUOTED] likes this.
  11. Jun 15, 2021 at 2:20 PM
    Anohibian
    Anchorage, AK
    I agree, the problem is they can’t find a leak. Makes no sense to me. Only thought I have is if it is a leak in a soft connection and putting a vacuum on it pulled it tight, so no leak, but if you put pressure in the system it opens back up. Of if there is a leak in the internals of the compressor that didn’t show if the compressor wasn’t cycling.
  12. Jun 15, 2021 at 2:22 PM
    HARPER306
    SK, Canada
    My money is on a leak. That being said when my ram was fixed under warranty, all they did was recharge the system, and it worked for the 2 more years I had it until I sold it. You are correct in your thinking of vacuum/no leak, pressure/leak thinking though
  13. Jun 15, 2021 at 4:15 PM
    Rocko9999
    Rocko9999 New Member
    There is a leak, don't let them tell you otherwise.
  14. Jun 15, 2021 at 5:03 PM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if it got so damn cold the O-rings shrank temporarily and it let it out in that subzero weather you have. Just a thought
    landphil likes this.
  15. Jun 15, 2021 at 5:29 PM
    Anohibian
    Anchorage, AK
    That crossed my mind. They say with the new refrigerant you should run your AC at least once a week to keep everything happy. Didn’t know that until after I found out it wasn’t r134 in the system.
    15whtrd[QUOTED] likes this.
  16. Jun 15, 2021 at 5:48 PM
    15whtrd
    15whtrd Mr. Blonde
    I figured my truck had the same stuff in it to until I read this thread. I’m pretty good about running it occasionally whether it’s defrost or air-conditioning. I’ll probably try to make sure I’m even better about it. My wife’s 08XB has never been recharged and still blows cold as ice. But I’m unaware what type of refrigerant is in it.
  17. Jun 15, 2021 at 5:57 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    It’s not that he’s trying to screw you, it’s that he doesn’t know how or can’t find the leak! It can be very time consuming to find a leak - especially some heat pumps, but that is no excuse to tell a customer there is no leak.
    rockmup and Jernik[QUOTED] like this.
  18. Jun 15, 2021 at 6:01 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Enviromentalist clowns. I love it when i do AC work be it R12, 134A or this crap vent directly to the atmosphere. fk them
    Hbjeff likes this.
  19. Jun 15, 2021 at 6:03 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    what so hard about finding leak??????? Charge and sniff every connection. No leak, stick detector in AC vents, leak? this isn't rocket science. You going to wrong idiot. sniff AC compressor where lines connect and pulley mounts. Two lines to condenser. What the challenge again????
  20. Jun 15, 2021 at 6:05 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    on Lexus I replaced ac compressor, condessor and drier, recharged. total cost $325 using Denso compressor an OEM supplier to Toyota.
  21. Jun 15, 2021 at 6:09 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    @Anohibian - as someone else stated, have someone fill the system with nitrogen to find the leak using soapy water (can also recheck next day with gauge- at same temperature). Also, never heard of the compressor being hard to turn due to low on refrigerant. That would be my clue to go somewhere else.
  22. Jun 15, 2021 at 6:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is there no ultraviolet dye in the system from factory? For leak inspection with a black light.
    15whtrd and FrenchToasty like this.
  23. Jun 15, 2021 at 6:10 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s leaking out of the Schrader cores when the gauges aren’t hooked up; assuming he tried to check for a leak by pressurizing and watching for the needle to drop.
    Sniffers are very helpful to find small leaks, ears and soap bubbles for big leaks.
    The Schrader cores/ caps are almost always the culprit in the one or two systems I’ve looked at.
    rockmup, Anohibian[OP] and 15whtrd like this.
  24. Jun 15, 2021 at 6:11 PM
    FrenchToasty
    Mo
    Bone stock
    Is there a Canadian version of “Bingo”
    landphil[QUOTED] and Dalandshark like this.
  25. Jun 15, 2021 at 6:14 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Hmm. “Bingo, ya hosers, eh”??? :notsure:
  26. Jun 15, 2021 at 6:26 PM
    15whtrd
    15whtrd Mr. Blonde
    I did it the old fashion way when I recharged my 91 work truck. Dab a little spit on the Schrader valve LOL
  27. Jun 15, 2021 at 6:29 PM
    FrenchToasty
    Mo
    Bone stock
    Haha when it’s to hot out and to far to the van to get bubbles, a lil spit will get you your answer
  28. Jun 15, 2021 at 6:35 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Do you have Cat shields? Maybe some thief stopped by to steal your cats, could not, got pissed and stole your freon instead.
    Bammer, Hbjeff and Anohibian[OP] like this.
  29. Jun 15, 2021 at 6:45 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    Most likely not the root of your problem, but this brings up an experience I once had, over 20 years ago. I knew a crooked mechanic one time that told me they’d disconnect an electrical connection or “bleed out” a little refrigerant from vehicles that came in to have service at their dealership regularly. They’d do it in cold, winter months so it wouldn’t be noticed until much later. Then, in the warmer months the customer would bring it in and they could charge to fix the unit. Quick, easy fix with big $$. He told me this because I was having trouble with mine and my regular servicing dealer wanted a lot to repair it. He bet mine was disconnected somewhere (not serviced at their location). We looked together and surely enough we found a plug, unlocked and pulled apart just enough not to work. Plugged it back in and and worked like a charm. I’ve done about all my own servicing since then.
  30. Jun 15, 2021 at 6:46 PM
    CENAIR
    CENAIR New Member
    PAUL
    I have been in business for 45 years for commercial Hvac and service many aircraft ac systems
    (which are the same as car ac systems), and the most common points for a refrigerant leak is the
    flexible hoses crimp connections, and compressor shaft seal.
    Techs should pressure test the system with refrigerant and nitrogen to max pressure which is published for the system on the nameplate, and use an electronic leak detector to find the leak and repair it.
    After the leak is found and repaired should be evacuated to 500 microns with a vacuum pump, and let sit to ensure no more rise of more than 100 microns, (600 microns) and after this test can be recharged with a digital scale for the proper refrigerant charge.
    R65, plumber802, BigSkyTaco and 2 others like this.
