Issues with Cluster Lights
Discussion in '1st Gen Tundras (2000-2006)' started by Bananabread123, Jan 21, 2024.
  1. Jan 21, 2024 at 4:38 PM
    Bananabread123
    Bananabread123 [OP] New Member
    2003 Sidestep AC Toyota Tundra
    Need some help diagnosing my problem here. I recent did a cluster LED swap. Everything works great except now my high beam indicator and right turn signal indicator no longer turn on.
    Originally both turn signals and high beam indicators had LEDs but decided they were too bright so I swapped them back to standard bulbs.
    Come to find out only the left indicator works but no longer right and high beam. My fuse isn’t blown I have checked that. High beams and right signal turn on fine on the outside, it’s just the cluster lights. I’ve swapped out bulbs to see if I had bad ones but no luck, I’ve also swapped the bulb housings and still nothing. High beam and right turn signal just don’t light up in. I also hear a low buzzing noise when LEDs are dimmed. When off or at max brightness buzzing goes away. TIA
  2. Jan 21, 2024 at 4:49 PM
    Paxmanhp
    Paxmanhp New Member
    Paxton
    North Carolina
    2000 Tundra Sr5 v8 2wd AC, AWD swapped
    AWD swap, HID retrofit, Sequoia center console, TRD Pro Tacoma shocks, Method wheels, custom bumpers, single pane rear window
    Did you change any other bulbs at the same time, i.e. headlights/ marker bulbs?
  3. Jan 21, 2024 at 4:56 PM
    Bananabread123
    I changed all T5s with LEDs and all T10s with LEDs. Same with HVAC controls swapped T10s with LEDs. I have since changed the clusters T5s back to OEM but have left the bigger T10s and one T5 as LED for backlight.
