Issues with BAK flip mx4 from real truck?
Discussion in 'General Tundra Discussion' started by 2025 Tundra, Jul 3, 2025 at 7:11 AM.
  1. Jul 3, 2025 at 7:11 AM
    2025 Tundra
    2025 Tundra [OP] New Member
    Yesterday
    I bought a 2025 Tundra in March and just installed a BAK flip MX4 cover and am having issues, curious if anyone else has seen the same.
    I cannot get all the latches to snap closed at the same time. The two closest to the tailgate are the worst, the ones behind give trouble but have been able to get both of these to latch at the same time. I have adjusted it multiple times and no matter what, at least one latch will not close. The cover also will not close with the tailgate closed.
    The other issue I have am having is water ingress, mainly from the corners closes to the cab. I have taken the cover off, adjusted rails, and reinstalled multiple times but cannot keep water out. It also leaks through the Styrofoam block where the hose connects. My main concern is that water just pools on in the back corners and sits on top of the holes I enlarged to fit the hose, I am concerned about damage to the composite bed with water pooling.
    Anyone else experience any of the issues and have any advice on how to mitigate? I bought from realtruck and am waiting to see if they or BAK has any advice.
  2. Jul 3, 2025 at 8:07 PM
    WWeasel561
    WWeasel561 New Member
    Greg
    2023 tundra
    Can’t help you with the water intrusion, but did you slide the mounting clamps into the rails, I had the same issue until I did this.
