Issues Installing Strut Spacer. Help Appreciated!
Discussion in 'Suspension' started by brian_k, Feb 13, 2018.
  1. Feb 13, 2018 at 7:48 PM
    brian_k
    brian_k [OP] New Member
    2002 Toyota Sequoia
    Hello, I am currently installing a 2 inch strut spacer, and I have ran into some issues at the very end. Basically I have the spacer on the strut, all I need to do is install it back on the truck. But no matter what I do I can't get the lower control arm low enough to get the bottom bolt in. I've tried spring compressors, and right now I have a nail setter that starts out at a point gets thicker that I'm wedging in but it just doesn't seem possible to get the bolt in. Right now I'm considering removing the upper ball joint tomorrow if I have time which should allow for me to get it in. Is this a good idea? Does anyone have any easier ideas? Any advice or tips would be appreciated, thanks!
  2. Feb 14, 2018 at 1:38 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Do you have the entire front end of the ground? If not raise both sides, if you do pull out your jack and wedge it upside down between the upper control arm and fender. That will move everything where it needs to be, it may also be necessary to install the lower shock bolt backwards from what it was.
  3. Feb 14, 2018 at 2:12 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    When I installed my coilovers I just unbolted uca from spindle only and pryed down on lca.
    Black Wolf likes this.
  4. Feb 14, 2018 at 10:59 AM
    brian_k
    2002 Toyota Sequoia
    Yes the entire front of the truck is off the ground. I’ll have to try that with the jack, I figured though that the fender might not be strong enough for the pressure. Thanks for the tip
  5. Feb 14, 2018 at 11:17 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Also unbolted swaybar.
  6. Feb 14, 2018 at 11:44 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    This is the right path, you should remove the spindle from the UCA, Disconnect sway bar, and loosen the lower control arm. Should be able to move the lower control arm down enough to get the coilover back in even with the additional length of the spacer. I had my brother helping my push the lower control arm down - it can be tough. I've also seen guys use a ratcheting strap to pull the lower control arm down to create more clearance
    Black Wolf and Casper3[QUOTED] like this.
  7. Feb 14, 2018 at 10:55 PM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    Man I just grabbed an extra set of hands. I had a huge pry bar I stuck against the lca and just pushed down. I had someone hold that spot while I replaced the bolt.
    A lot of these other ideas could work just as well.
    equin likes this.
  8. Feb 14, 2018 at 10:56 PM
    Phillipk98
    2005 sr5 sequoia
    Make sure you get an alignment after. You probably know that though.
  9. Dec 30, 2018 at 10:17 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Hey, do you know if the TRD skid needs to be removed to install ??
    Rica25 likes this.
  10. Dec 31, 2018 at 7:43 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    I’m not sure I’m in understanding what the other dude recommended, but definitely don’t jack against your fender. You’ll destroy it.
    As other have said, just push harder on the LCA to get the bolt to line up. It helps if you have a buddy there that can put a foot on the LCA and push down as you get the strut in.
  11. Dec 31, 2018 at 8:20 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    OP has a 1st gen Sequoia. The inner fenders on those and the trucks are strong enough to jack against to get the lower shock mount aligned. It doesn't take much maybe 3/4" and working by yourself is much easier than prying down while trying to get the bolt in.
    Not saying it would be advisable on anything newer than 06.
