Issues installing Morimoto XB LED Fog light on 2007 Tundra limited
Discussion in 'Lighting' started by alphak25, Feb 10, 2020.
  1. Feb 10, 2020 at 1:36 PM
    alphak25
    alphak25 [OP] New Member
    Hi All - I figured I would check before reaching out to @Headlight Revolution, but I recently sourced a XB headlight (on backorder) and fog light kit and attempted to install the Fog lights today. Needless to say, I had an issue getting the supplied H10 connector to fit in the factory harness ... super tight and wouldn't push in. Could be the tolerances are off slightly, but wanted to check to see if i'm missing something before returning these or reaching out to customer service.
    Thanks in advance.
  2. Feb 10, 2020 at 1:46 PM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Mind sending me a PM with your Order Details? I'll get this situated for you!
    Sas and Toyokuhl like this.
  3. Feb 10, 2020 at 2:55 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Check plug orientation. If pins are reversed, mine was, it will not plug in.
  4. Feb 26, 2020 at 10:29 AM
    alphak25
    Just got back from vacation to find my headlights had arrived (I managed to figure out the fog light install with help from Brandon!). Here's the finished product, very happy, will report back once I get them on the road at night.
    One question though (and i'm sure that people have encountered this) I managed to break the clips on the lower plastic trim piece (must be the cold winters here in MN). Is there a factory replacement or hack as it's now blowing in the wind?IMG_1027.jpg
  5. Feb 26, 2020 at 10:35 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    same thing happened to me when I did my LED bulb upgrade to the wife’s Sequoia... thank goodness the wife doesn’t look that close at the headlights :fingerscrossed:
  6. Feb 26, 2020 at 10:37 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I think @Roman can help you w/that.
    Roman likes this.
  7. Feb 26, 2020 at 10:39 AM
    alphak25
    Sas likes this.
  8. Feb 26, 2020 at 10:40 AM
    BrandonL812
    Brandon
    Roman and Sas like this.
  9. Feb 26, 2020 at 10:48 AM
    alphak25
    Yes, those are the ones! Thanks.
    Headlight Revolution likes this.
  10. Feb 26, 2020 at 11:21 AM
    TheBeast The Beach
    very nice upgrade !
  11. Feb 26, 2020 at 11:39 AM
    alphak25
    Thanks! Next will be a light bar of some sort!
  12. Apr 23, 2020 at 9:22 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    @alphak25 can you share how you resolved the connector issue? i've got to be doing something wrong. even without the wire/pins installed i can't get the supplied connector to snap in place with the oem female end. it's short by maybe 1/8 or so inch. the morimoto online install guide is of no help. thanks.
  13. Apr 23, 2020 at 9:26 AM
    alphak25
    I used a channel lock wrench, positioned the wrench to grab the back of the female housing and little bump on the male housing, then squeezed! Make sure the pins are well aligned before attempting.
  14. Apr 23, 2020 at 9:30 AM
    sensei
    thank you very much. i started to go that route then backed off figuring i should ask around before using force. whenever i use force...the force is never with me and i end up costing myself $$ to revert. lol.
    but sounds like once i put them on and get it snapped in, prob won't be able to unplug them cleanly. wish they wouldn't have made it so tight but i get that it needs to be weather proof.
  15. Apr 25, 2020 at 12:20 PM
    sensei
  16. Feb 26, 2022 at 11:44 AM
    11CMGray
    11CMGray New Member
    Hey there, is there a particular way/side these go in? I put them on one side and they don't light up.
