Issues after Lift upgrade/big tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by mynor213la, Aug 26, 2019.
what issues you encounter after the lift and mud tires
  1. bad
    4 vote(s)
    25.0%
  2. good
    14 vote(s)
    87.5%
Multiple votes are allowed.
  1. Aug 26, 2019 at 3:34 PM
    mynor213la
    mynor213la [OP] New Member
    mynor
    17 tundra LMT 4x4
    none
    Hello My Tundra family,
    i just wanted to know what issues have you experienced after doing the lift suspension upgrade and 30s, 35s mud tires.
    what are the pros and cons.
    im getting a lot of negative feedback lately.
    mynor
    jewsNbrews likes this.
  2. Aug 26, 2019 at 3:39 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Depending what you want, you should be fine. Most issues are with 18+ models with tss sensors.
    17 should be good to go. Just depends what you want and how much :sawzall::welder:you're willing to do.
  3. Aug 26, 2019 at 3:40 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I lifted 3 inches, put 33.16" tires on and zero issues on my '18 cm. 35s were too big for me because i think the gain is outweighed by the work i would need to do to get them to fit
    Tierhog and jewsNbrews like this.
  4. Aug 26, 2019 at 3:40 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    I originally did 7" lift and 35s on 2019 only issues were my lane departure alert was hit and miss probably because it is so much higher than stock but I never use it except to test it out because I dont need my truck to beep at me reminding me I forgot to use my blinker or when I use 2 lanes taking corners on a back country road.
    Only other problem I encountered was with the big lift my 35s looked to small so I had to go bigger now running 38s and everything still works just fine.
    But there are a few threads of people discussing there own personal issues if you look around. It seems to be case by case
    Bigboitundra and jewsNbrews like this.
  5. Aug 26, 2019 at 4:13 PM
    Bought a used 2014 with 26000 miles, now I'm at 71,000, the front end is starting to make a lot of creaking noises I'm sure everything needs to be re-torqued down, and I'm also pre 2017 TSS, I'm sitting on 35s 20 by 9 wheels positive 20
    georgiey22 and jewsNbrews like this.
  6. Aug 27, 2019 at 11:25 AM
    megatundavid
    megatundavid New Member
    David
    Norcal
    2014 Tundra crewmax 4x4
    Magnusen supercharger and Bullydog tuner TRD PRO Grille with ENVE Grill insert. ICI Magnum front bumper with LED driving lights Radium Engineering dual catch cans 2018 factory LED headlights Firestone airbags with in cab controller Banks catback exhaust system Baer Brakes front drilled and slotted brake rotors All seats have had seat covers most of their lives Ready Lift 6" suspension lift 18" KMC wheels with 35" Cooper STT PRO's AMP Research power side steps Spray in bed liner IPT modified valve body for transmission Factory tow mirrors Light tint on front windows Hypertech speedometer calibrator. Husky floor liners.
    2014 with a 6" lift and 35's. I have 42K miles with no issues as of yet. When I need tires, ill put on the 2" adapter kit from ready lift to mske it 8" nd put on 37's
    AZTundra and Bigboitundra like this.
  7. Aug 27, 2019 at 11:35 AM
    chphilo
    chphilo Tundra addict
    Western PA
    3 & 1/2 inch in the front and 1 & 1/2 inch in the rear (OME kit). 295/70/18 mud tires. Love the look. No issues
    Con: Uses more gas. Shop people who rotate my tires complain about how heavy tires/wheels are. I hurt my knee once and it was quite painful trying to get in the truck.
    Tundraman1000 likes this.
  8. Aug 27, 2019 at 2:58 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    2018 with Pro Comp 6" lift and 35's. No issues with sensors or lane departure. No creaking. Only "issue/s" (but I knew this going in) is reduced turn radius and reduced fuel economy. If I could do it over again, I would probably go to 4" and 34's.
  9. Aug 27, 2019 at 3:06 PM
    Bigboitundra
    Bigboitundra New Member
    2018 tundra crewmax
    7 inch lift
    2018 with 7 inch pro comp lift and 35s toyo..r/t
    Drives great no problems..
    Would do it again in heartbeat
    jeremyd and Tundraman1000 like this.
  10. Aug 27, 2019 at 3:15 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Well spoken sir.
    Well equipped Toyota LANDCRUISER on 33/34s.
    XPTUNDRA, jeremyd, HutchFla and 5 others like this.
  11. Aug 27, 2019 at 3:50 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    ttt.jpg 6 inch , zero issues.
  12. Aug 27, 2019 at 3:52 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    7 inch BDS 22x12’s and 35’s. Zero issues so far.
    Getmeacoors and Bigboitundra like this.
  13. Aug 27, 2019 at 10:02 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Beautiful LC
    Tundyfundy likes this.
  14. Aug 27, 2019 at 10:31 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Aussies sure can build em. Wish I had one... Lol
    Shhhhhhhh.
  15. Aug 28, 2019 at 12:10 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Had to have my PCS re programmed after my lift was installed, OME 612. The PCS, LDA and cruise control went all wanky. Its a roll of the dice on if it will happen on 2018 and up. Mines a 2019.
  16. Aug 28, 2019 at 2:33 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I’m at a 3/1 leveling kit on 33.2. I had to add wheel spacers to fill out the look but it’s well worth it for gas savings and power savings. No re-gearing/body mount chop. I can still get 16.2 AVG if I baby her. Looks great and still tows like a beast!
    PS Coilovers with rear shackles + upper control arms.
    HutchFla and Toyokuhl like this.
  17. Aug 28, 2019 at 7:38 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I was into lifts and tires with the Jeeps of my youth.
    If I ever lifted a Tundra I'd consider an old man emu along the size you described.
    Most quality lifts have adjusted front spring rates to handle large bumpers and winches.
    Sounds like you found the perfect compromise. I wonder what the largest tire size stock with full flex while in a hard turn is... Hmm.
    Tundyfundy[QUOTED] likes this.
  18. Aug 28, 2019 at 8:08 AM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    have 3/2 lift and 34's no issues so far except a slight rub going right
  19. Sep 2, 2019 at 4:20 PM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    I have a 6” Ready lift with 35” Toyo MT’s. I will move to the Ridge grappler or similar when they go bad. I love everything about it. Other then the tires, it drives exactly like a stock truck. I have Put 20k on it in 7 months. AB4C2B5B-A5CC-4505-BEAD-93AFB9EF8B18.jpg
    Bigboitundra and jeremyd like this.
  20. Sep 2, 2019 at 4:27 PM
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    Just getting the alignment dialed in is my only issue so far on my 8" ReadyLift. I have the right tie rod just kissing the spring when fully locked right. Boss 4x4 sent me the alignment specs they have had success with so I will have the shop realign when it goes back in for it's re-tourquing. It rides great so far and look really awesome .
  21. Sep 2, 2019 at 4:44 PM
    Midway
    Midway New Member
    I've had Zero issues after getting lifted (3" front 1.5" rear). I went exclusively with an installer that has delt with the 2018 TSS stuff. I had excellent alignment numbers, too.
    Running BFG KO2s (35X12.5R17)
    BMC/CMC: No rubbing
    Camberg UCAs
    King Coilovers (Front & rear).
    CB Lift shackles
    Differential/carrier drop.
    Nitro 4.88s
    The only real adjustment was getting my tow hitch shank set up for the additional height increase
    I'd also lift it again in a heartbeat vs. being stock
  22. Sep 2, 2019 at 4:47 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    None.
    jeremyd and LastCanadianExit like this.
  23. Sep 2, 2019 at 5:43 PM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    315/70r17 ridge grapplers w the radflo 3”/1.5” and have zero issues now. Did the spc uca’s and also added shims to the front bumper to poke it out a bit since there was a little bit of rubbing on the front plastic off the bumper. Fuel mileage has gone down a bit but that was expected. Wouldn’t go back to stock even if I could. Love the lifted ride it changes everything about the truck in a positive way.
  24. Jan 13, 2021 at 9:06 PM
    Rebel256
    Rebel256 New Member
    Travis
    16 CrewMax SR5 TRD Offroad w/6" Lift
    2016 with 6 inch Rough Country lift.
    I have a lot of noise in the front when turning, I want to upgrade my steering rack but haven't found anyone to help me decide what route is best.
    It pops and creaks every time I back out of the driveway.
  25. Jan 14, 2021 at 12:32 AM
    preacher35
    I doubt that the noise you are hearing is the steering "rack". Did your 6" RC lift require the crossmember cut and diff drop? I think that their older versions did not. If your kit is one of RC's older versions, than your front CV's and drive shafts are at a very steep angle. And, when turning the wheels when backing out, they are going to be very noisy. Only way to resolve that is to update your kit with a newer version that requires the crossmember cut and diff drop. But, if you really think it is the steering linkage that is making the noise, Coachbuilder makes a kit that helps a little bit, with that:
    https://shop-coachbuilder.myshopify.com/collections/coachbuilder-steering-upgrade-kits
    I have asked members if anybody has this kit installed, and I know a couple that do, but have NOT gotten any feedback on how much it helps.
  26. Jan 14, 2021 at 1:31 AM
    TXTundra2722
    2015 Black Tundra
    I just did the CB poly bushing upgrade for the steering rack this past weekend and all I can say is that it gave it a "Sportier" feel to the steering. I'm interested in the benefits of upgraded tie rod kit from CB as well.
  27. Jan 14, 2021 at 4:54 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Got 6" lift with 35s, the only issue I had was parking. I couldn't see anything when forward parking, got a Front Anytime Camera .....Problem Solved :thumbsup:
    BUGEATER and TXTundra2722 like this.
