ISSUE: Installed Ditch Lights, now Clock and Radio backlight turns off when headlights are on.
Discussion in 'Lighting' started by SC_TRD, Jun 24, 2020.
  1. Jun 24, 2020 at 9:47 AM
    SC_TRD
    SC_TRD [OP] Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Hi All,
    I just installed a pair of Baja Designs Squadron Sports using the wiring harness that came with the lights. I wired them up to one of the square OEM type switches purchased from Rago Fabrications. Lights work with no issues, and do not affect anything when I turn them on. BUT, when my headlights turn on, my entire Stereo Head Units becomes dark (but continues to play music), the Clock built into the center of the dash (I have a 2nd gen) goes dark, and the air conditioning/heater display also goes dark. Everything works with the backlighting off, just cant see anything. I checked the dimmer switch already and of course that isn't the problem.
    I am guessing I may have blown a fuse, and will start working on investigating that route. If anyone has seen this before and knows the answer I would really appreciate the help. This was my first time doing electrical in a LONG time, so not really surprised I messed something up =/
    Happy to post pics of whatever if it will help.
    Thanks!
  2. Jun 24, 2020 at 9:50 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Which wire did you tap for the switch backlighting? If you pull from the wrong one it can do some wild stuff with dash lights, DRLs, etc.
    Black Wolf and SC_TRD[OP] like this.
  3. Jun 24, 2020 at 9:56 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I definitely tapped something wrong.. I used the one of the wires on the Tow Haul switch, which seems to have a constant voltage, so the button is constantly lit instead of when headlights are turned on... I removed the T Tap to this wire believing this was clearly the issue as well, but did not change anything once removed. Maybe I could try removing and disconnecting the battery hoping everything will reset..? I'll go snag a picture too. But as mentioned, definitely did not connect to the Dash Light Circuit which I believe is a light blue wire ..=/
  4. Jun 24, 2020 at 10:00 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Pictures of what I did
    017D4E50-F17B-4E2A-A52F-67E73D35A362.jpg E76F8336-E1CD-47B5-8158-D592BC98199E.jpg
  5. Jun 24, 2020 at 10:04 AM
    Squatting Pigeon
    Holden
    North Texas
    Try twisting both red wires together and see if that solves the dash light issue. the backlight on the switch will be messed up, but it might shed some light on what’s going on.
    Did you run power straight from the battery to the switch, or tap something else?
  6. Jun 24, 2020 at 10:07 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Power is run straight from battery. I can try twisting together, but I think I could achieve the same result by just un tapping the tow haul and leaving that wire just dangling.. then only 1/2 button will light up... but good enough for diagnostics.. everything else now is self contained, didn’t tap into anything else and the problem persists
  7. Jun 24, 2020 at 10:27 AM
    Squatting Pigeon
    Holden
    North Texas
    I just wonder if having that second red wire off leaves the circuit open. Probably won’t make a difference, but worth trying IMO.
    Did you try unhooking the battery for a while and checking again?
  8. Jun 24, 2020 at 10:33 AM
    SC_TRD
    Colin
    Round Rock, Tx
    thanks for the help and time!
    I just tried unhooking the battery waiting for a minute and re-connecting.. issue persisted.. I tried again and actually removed the ditch light connections from the battery as well so it was completely removed from the trucks electrical circuit and the problem still persisted... I now have everything re-connected except for the T Tap I had initially plugged into the tow haul and of course issue is still happening =\....
    Headlights off:
    Headlights on:
  9. Jun 24, 2020 at 10:36 AM
    Squatting Pigeon
    Holden
    North Texas
    Did you pull that T tap off the tow haul switch wire completely?
    It’s possible it severed that wire.
  10. Jun 24, 2020 at 10:44 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Ahh that was a good idea! I had pulled the t tap completely off, but not inspected the original wire... in looking at it, it seems undamaged and tow haul is working.. but now that I am looking it does seem the backlighting isn’t working for any of my standard switches either when the headlights are turned on... I’ll peel the wire open a bit and confirm it’s intact
  11. Jun 24, 2020 at 10:53 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Wire is intact, was able to tap into it where it enters the back of the switch and confirmed voltage was still present on the wire =/
  12. Jun 24, 2020 at 10:56 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Since the whole backlighting circuit appears to not be working is there a possible fuse or something else...
    Squatting Pigeon likes this.
  13. Jun 24, 2020 at 10:56 AM
    Squatting Pigeon
    Holden
    North Texas
    Well damn, I was hoping that would be it!
    Have you gone through all the fuses yet?
    SC_TRD[QUOTED][OP] likes this.
  14. Jun 24, 2020 at 10:59 AM
    SC_TRD
    Colin
    Round Rock, Tx
    thinking the same things... I’ll check them and see if something blew
  15. Jun 24, 2020 at 11:25 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Don’t think it’s a fuse....
  16. Jun 24, 2020 at 11:34 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    I had a very similar issue on my 2020 Platinum after installing the anytime back up camera kit...all back lights come on except my radio buttons (“menu”, “audio”, “map”, etc)...the climate control back lights work, and even the new camera switch has back lights, but yet the radio doesn’t...still haven’t figured it out!
  17. Jun 24, 2020 at 11:44 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I have found this from internet scavenging:
    now this might not be exact as it is pretty dated. But seems very accurate to the problem at hand.. anybody know anything about this combo pin?
    Tundyfundy, AZTundra and 2020Platinum like this.
  18. Jun 24, 2020 at 11:57 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've had that connector out when I put in my speedometer calibrator - it's not that hard to get to, but I don't know that you'll have a ton of room to work with when you get back there... I only pulled it apart the one time. Looks the same for late models, so I'd imagine you're onto something. Good luck!
    SC_TRD[OP] likes this.
  19. Jun 24, 2020 at 11:58 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Also, when I installed my Cali Raised kit, it had the same style button and the red/orange wires were twisted together and butt connected to the illumination lead from the light harness.
  20. Jun 24, 2020 at 12:23 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    https://www.youtube.com/watch?v=W4MXEJpedrM&feature=youtu.be
    At the 3:40 mark(ish) he talks about using the red wire closest to the black to tap into the factory dimming line... I can't quite tell from the angle of your pic, but it looks like you may have used the other one and back-fed from the harness.
  21. Jun 24, 2020 at 12:30 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I definitely watched this exact video and a number of others haha.. Yes I did tap the red wire closest to the black, but I believe I tried the other wire first, but I also hooked up the lead to the battery at the very end to try and make sure I didn't do anything silly like this.... :monocle: Who knows, clearly I angered the electrical system though.
    Thank you for the help!
  22. Jun 24, 2020 at 1:04 PM
    SC_TRD
    Colin
    Round Rock, Tx
    What did I get myself into??? :eek2:
  23. Jun 24, 2020 at 1:09 PM
    SC_TRD
    Colin
    Round Rock, Tx
    So @TRDFerguson pin 37 on this bad boy is what we’re were talking about?
  24. Jun 24, 2020 at 1:11 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep that looks like the one.
  25. Jun 24, 2020 at 1:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Me a couple weeks ago trying to track down one shorted wire. Get ‘er done Colin, you have a trip to go on in a couple of days!!!
  26. Jun 24, 2020 at 1:15 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Looks like this is the wire For the next fellow that has to deal with this:
    TRDFerguson likes this.
  27. Jun 24, 2020 at 1:17 PM
    SC_TRD
    Colin
    Round Rock, Tx
    hahah nice! Ya, trying to get it handled before kids get home haha.
    like my copilot?!
    TRDFerguson and joonbug[QUOTED] like this.
  28. Jun 24, 2020 at 1:35 PM
    SC_TRD
    Colin
    Round Rock, Tx
    any suggestions on how to tap into this pin?? Can I just use a t tap on the wire and then connect to the ground?? I ask because this is what I tried and had no luck..
    I really am pretty green when it comes to electrical
  29. Jun 24, 2020 at 1:40 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  30. Jun 24, 2020 at 1:41 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I have had success using Posi-taps. Especially for the smaller wire gauges.
    Best luck!
