Is this working correctly?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 45er, Dec 30, 2021.
  1. Dec 30, 2021 at 1:40 PM
    45er
    45er [OP] New Member
    Rob
    2021 SR5 Crew Cab 4x4
    Tonneau Cover
    I have a 2021 Tundra SR5 4WD truck. I like the feature that "beeps" when the truck is approaching (or being approached) too closely. It has already "saved" me from accidentally backing into a trailer hitch!
    It seems to work great when something approached from the front side or the rear. Beeps like a chicken when I'm in tall grass or pulling a trailer. I have to turn it off or it would drive me crazy. The problem is that when I pull straight into my garage, I can drive up to within a foot of my garage wall and the dang thing doesn't beep?
    Is this normal? Does the system just expect you not to drive into walls? (LOL) It's not a big deal, but I would think that a warning system like this would work directly in front of the vehicle.
  2. Dec 30, 2021 at 3:15 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    They work best at detecting objects off center better than straight ahead.
    Sounds like they are working correctly
  3. Dec 30, 2021 at 3:16 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    this ^ The sensors are not pointed forward, they point out to the sides a bit. Guess that is to help with turning clearances. Your truck is working as designed.
  4. Dec 30, 2021 at 3:18 PM
    45er
    Rob
    Tonneau Cover
    I appreciate these responses. I went outside and tested my wife's 2020 Highlander. Her beepers work dead ahead. I guess it's just a bit different in the truck.
  5. Dec 30, 2021 at 6:02 PM
    Bentarm13
    Bentarm13 New Member
    Correct, go through a drive-thru close to the wall and the truck hits defcon-9, nose up to a vehicle and nothing. Great for side impact, useless for direct impact??
  6. Dec 30, 2021 at 6:39 PM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I have a similar problem. I can barely get behind my truck with the door closed unless I'm very close to the front wall. I've got a shelf on that wall, and I hung a piece of cord about 3" from the wall on that shelf, and I pull forward slowly until I see if move. Sometimes the lo-tech kludge is all you can do ;)
    normagene likes this.
