Is this true and if so why do we have 4wd or All Wheel Drive?
Discussion in 'General Tundra Discussion' started by 303Gen3, Jan 19, 2024.
  1. Jan 19, 2024 at 5:07 PM
    303Gen3
    303Gen3 [OP] Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Recently I made a post that stated "4x4 may give you traction but it does not let you stop any faster." I have always thought this to be the case. Now I am conflicted after being informed of the following by one of our Tundra members:
    "The only way to get more traction is to physically change something about your contact with the road with different tires, chains, traction boards, etc."
    Please tell me the truth then I can sleep at ease. TIA.
    coTony and T-Rex266 like this.
  2. Jan 19, 2024 at 5:14 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Well I got stuck in 2nd today; spin in 4hi and crawled out easily in 4lo. Definitely felt traction with 4lo. Used 4hi many times previously and got me out of jams where 2nd wouldn’t work. That’s good enough for me to say it works
    bulldog93 and 303Gen3[OP] like this.
  3. Jan 19, 2024 at 5:15 PM
    Power is shifted to all four wheels in 4WD
  4. Jan 19, 2024 at 5:36 PM
    It is more traction. In 2wd only half your wheels are spinning to produce drive. In 4wd you are engaging all the wheels to grip and push/pull. It's twice the traction.
  5. Jan 19, 2024 at 5:49 PM
    303Gen3
    Golden Colorado
    Yes - the intended purpose of 4wd. Could not agree more.
    swede78 and T-Rex266[QUOTED] like this.
  6. Jan 19, 2024 at 5:58 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Could not have got out of my neighborhood earlier this week in 2WD. Ice storm. 4WD got us out. Call it traction, power, whatever, 4WD gives you more.
  7. Jan 19, 2024 at 6:43 PM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    Semantics... Sounds like the Tundra member you mentioned was disputing your choice of the term "traction". They are technically correct on that one count but wrong in every other sense of the conversation in play.
    Each tire has "X" amount of grip/traction and only by changing something physically does a given tire suddenly have more (or less) traction. What the poster was not taking into account or perhaps being deliberately obtuse about was that that the more tires that are being driven the more total drive/grip/traction is availible to accelerate.
    So your statement is correct (minus the semantics issue). 4x4 even with open diffs has more grip/traction to accelerate because more wheels are being driven compared to 2 wheel drive vehicle with an open diff. However neither one has an advantage when it comes to stopping if all other things about them were equal since they both have brakes on all 4 tires.
    We've all witnessed the new or careless 4WD owner use the extra grip to accelerate faster and go faster in slick conditions only to find out too late they can't stop any faster than anyone else...
    Saltyhero13 likes this.
  8. Jan 19, 2024 at 6:44 PM
    I know who this thread is about btw:p
  9. Jan 19, 2024 at 6:46 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    4x4 does not help you stop any faster
  10. Jan 19, 2024 at 6:49 PM
    Correct, because you already have brakes at all 4 corners. The drive system isn't using traction to decelerate, the braking system is.
    Oey12, reywcms and T-Rex266 like this.
  11. Jan 19, 2024 at 7:43 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I'll quote myself in (since it is about me). @windblown101 you are correct it was a very semantic argument that is taken out of context with that single sentence :)
    I was not trying to even start an argument just wanted to rant about the semantics of a very common phrase that people whip out in the winter
    Cpl_Punishment, GODZILLA and T-Rex266 like this.
  12. Jan 19, 2024 at 7:46 PM
    APalmTree
    Brandon
    SW Washington
    :humble:
    hagrid, Black Wolf, OldGuy03 and 2 others like this.
  13. Jan 19, 2024 at 11:05 PM
    blenton
    blenton New Member
    And to throw gas on the fire… I would disagree. Simplified version of disagreement reads: static friction is higher than kinetic friction, meaning a rolling tire has more traction than a skidding tire. Weight shifts forward while stopping (on slick roads, it is less than the traditional 70/30 split rule of thumb) so those tires will typically lock first. ABS is supposed to prevent them from locking but in reality on slick roads they will still lock but won’t instantly spin up again before the ABS cycles and pulses again due to the lower coefficient of friction. In 4wd, the front and rear axles are forced to rotate at the same speed, so the rear tires not skidding will keep the front tires rotating, thereby allowing a higher coefficient of friction between all four tires and the road - which is what ABS tries to do but isn’t always effective. Hence better traction while stopping.
    :boink:
    Boerseun, landphil and Black Wolf like this.
  14. Jan 20, 2024 at 6:21 AM
    windblown101
    Old school 4x4 with no ABS and no center differential: All things being equal if both fronts are in a skid the rears will simply be forced into a skid as well as they have a lower traction threshold. The rears will take their queue from what the fronts are doing. Sort of a chicken or the egg thing I suspect...
    But what happens if only one front tire is in a skid? What impact if any will the brake proportioning valve have?
    In the end no matter what they're driving they'll stop quicker when they plow into the vehicles stopped in front of them. Folks driving in slick conditions should take a page from the boaters handbook - Never approach the dock faster than you want to hit it... ;)
  15. Jan 20, 2024 at 6:34 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Black Wolf, OldGuy03 and T-Rex266 like this.
  16. Jan 28, 2024 at 6:09 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Yada yada yada.
    Spend the money on quality winter tires if you live where there's snow/ice 3 mo p/yr and don't drive like an idiot.
    And actual, bonafide winter tires. Not the A/Ts that you think look cool and have a bullshit snowflake on the side.
  17. Jan 28, 2024 at 8:18 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Traction is being able to apply a force to a surface and creating motion. But it only works within a window of not being too heavy or too light on the surface. Since pickups are front heavy a 2wd pickup can get stuck on flat wet grass. Adding weight to the rear could be enough to create traction. Or adding power to the front wheels will do it too.
    4WD won't give you better hydraulic braking. But it could give you better engine braking in low traction. And far better engine braking when it's in low range. But the disc brakes....no.
    4WD has a low range gear and direct 4WD transfer case with no slip which is better in working and off road applications. AWD systems don't have a low range gear and allow slip in the transfer case between the front and rear. AWD is better is most on road applications thats why they are found in cars where 4WD is found in work vehicles like trucks. Some vehicles have both like high-end SUVs and trucks like the Sequoia or a Chevy Tahoe.
  18. Jan 30, 2024 at 3:43 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Winter tires makes all the difference.
    All Season tires are like the shirts that say, "One size fits all":monocle:
    baraynavab likes this.
  19. Jan 30, 2024 at 4:11 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In 4WD you get perhaps 3-4 times the traction, because most of the truck's weight is situated right above the front axle.
  20. Jan 30, 2024 at 4:18 AM
    surfmonkey
    surfmonkey New Member
    2024 Tundra Limited
    Full tank of gas
  21. Jan 30, 2024 at 4:27 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    I don't think anyone is arguing that you have more traction with AWD or 4wd and can keep going.
    The issue IMO is people tend to drive faster with AWD and 4wd on - thus making stopping distances greater.
    And this can be dangerous depending on conditions as you cannot stop faster - assuming same tires and everything else same outside of AWD / 4wd option.
    As soon as you sense slip - people tend to slow down.
  22. Jan 30, 2024 at 4:45 AM
    coTony
    Tony
    Montrose, CO
    It is very easy to figure out traction and how it works. Obviously 4WD helps because you now have more than one wheel trying to move your vehicle so that is traction 101...
    "We have come to the conclusion that we can run our car over any road that a man can take a team of horses and a wagon, providing we can get traction." Dr. Horatio Nelson Jackson, 1903
    This was the phrase Kevin Patterson (RIP) had in his signature on ih8mud.com and we all lived by it.
  23. Jan 30, 2024 at 5:18 AM
    Retired...finally
    I thought I read somewhere that to be an all-season tire required just 1/32" of tread depth over a summer tire.....Or was that Mud & Snow.
  24. Feb 13, 2024 at 3:19 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    4x4 = more traction in all wheels...so you can "potentially" get unstuck in low traction places. 4-LO = higher torque to the wheels.
    If you want to stop that's investing in better brakes/rotors and tires.
  25. Feb 13, 2024 at 4:47 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I heard caster is the key and eliminates the need for 4wd. Pair that with the added weight of 5W-30 and you don't even need brakes.
    While none of this is true, I figured I'd use the opportunity to ask what it is just read about.
    Traction = good.
    More drive wheels with traction = better.
    Lubrication (snow, ice, rain) impacts traction = bad.
    Heavy vehicles take longer to stop = worse.
    People driving heavy vehicles on slippery surfaces thinking they are immune = segment on World's Dumbest Drivers.
  26. Feb 13, 2024 at 6:18 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It depends. Heavier vehicle with narrow tires could stop faster in snow than lighter one with wide tires. There's no universal combo that is better in all cases.
  27. Feb 13, 2024 at 6:48 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Note that I did not include the fat vs skinny debate. We all have our preferences. ;)
    But this is all a matter is science. Intro in the link below:
    "Some seem to have the notion that driving a four-wheel drive with anti-lock brakes somehow exempts them from Newton’s three laws."
    https://www.langleyadvancetimes.com/opinion/editorial-newtons-law-of-winter-driving-2483777
    The last post does an even better job at explaining.
    https://www.physicsforums.com/threads/newtons-first-law-of-motion-skidding-on-icy-roads.3355/
    Overcoming the "from rest" is where AWD/4wd plays a part. Overcoming the "in motion" it offers zero assistance.
  28. Feb 28, 2024 at 11:22 AM
    boatsnbikes
    boatsnbikes New Member
    4x4 does not give more traction. It simply allows all 4 to spin. Traction is only accomplished on the ground by what is touching the ground
  29. Feb 28, 2024 at 12:57 PM
    No, that is friction. Traction is the application of torque that uses the friction to provide momentum. Google "tractive force"
    Eurodriver and T-Rex266 like this.
  30. Feb 28, 2024 at 1:20 PM
    Think of friction of a penis rubbing on a vagina. Think of traction when if, when inserted, if there’s any traction (feel) or if it’s like throwing a football down an empty hallway. That should pretty much sum it up.
    hagrid, Azblue and NWPirate like this.
