Is this the only screw protector for the Speedo?
Discussion in '3rd Gen Tundras (2022+)' started by TundraFl83, Jun 28, 2024.
  1. Jun 28, 2024 at 3:54 PM
    TundraFl83
    TundraFl83 [OP] New Member
  2. Jun 28, 2024 at 4:05 PM
    Breathing Borla
    AZ
    Screen protech is legit , that’s what I have on the big screen and the digital gauge
    Really good stuff
  3. Jun 28, 2024 at 4:15 PM
    TundraFl83
    Did you order it from the same site ?
  4. Jun 28, 2024 at 4:21 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Breathing Borla likes this.
  5. Jun 28, 2024 at 4:33 PM
    Breathing Borla
    AZ
    no, I got it right from them with a discount code
  6. Jun 28, 2024 at 5:19 PM
    TundraFl83
    Ordered from their site . Thanks again guys
  7. Jun 28, 2024 at 6:17 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I had a pretty bad experience with screen protect. I would not recommend it at all. Didn’t fit properly, AC control section was total garage, they don’t respond much. They didn’t want to refund me either, they wanted me to send the installation accessories back for a partial refund. Ended up disputing with PayPal and got a full refund.
    pwpblue likes this.
  8. Jun 28, 2024 at 6:20 PM
    TundraFl83
    Lmao damn it bro too late now I ordered .
    did you try a different kind ?
  9. Jun 28, 2024 at 6:26 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I got a glass spigen from Amazon. Works great anti glare and was easy to install. That is for the radio screen though. Haven’t found anything yet for the speedo.
    PNW Tundra Mike likes this.
  10. Jun 28, 2024 at 6:29 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  11. Jun 28, 2024 at 7:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    The screw protectors for my speedo are sold seperately & individually wrapped.
    NWPirate and hagrid like this.
  12. Jun 28, 2024 at 8:06 PM
    TundraFl83
    So weird couldn’t find jack squat on Amazon for the speedo, what gives
  13. Jun 29, 2024 at 3:01 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    You could probably just make one from paint protection film.
  14. Jun 29, 2024 at 6:58 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    It does take time to put the film on, easiest was the 14" multimedia screen just because there's nothing around it. When I did mine I removed the surround from the gauges so there was nothing getting in the way. When I first peeled the multimedia protector off the sheet it folded over onto itself and I almost threw it out. It stuck to itself and was almost impossible to separate. My advice is get a corner started and before pulling it off the sheet spray down the front a little. Start peeling it off the sheet and spray it as you pull it from the sheet. With both sides wet if it folds over on itself you'll be able to separate it from itself easily. Also stuff paper towels under whatever panel your doing to catch the dripping water. The more water you use the easier it will be, keep it wet.
  15. Jun 30, 2024 at 12:20 PM
    TundraFl83
  16. Jun 30, 2024 at 12:20 PM
    TundraFl83
  17. Jun 30, 2024 at 6:33 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Good luck my issue was fitment then customer support
  18. Jul 25, 2024 at 6:19 AM
    TundraFl83
    Finished installing it weeks ago . The Speedo was a pain in the ass . Bubbles took almost two weeks to disappear . The infotainment was easy af . The shifter area forget it , I screwed that one up
  19. Jul 25, 2024 at 7:29 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This is how M&M candies should be packaged.
    TundraFl83[OP] likes this.
