Is this my battery??? 5 month old Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by ProtoJ, Mar 9, 2019.
  1. Mar 9, 2019 at 2:24 PM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    Loud clicking....headlights flickering, dash gauges turning on and off? Looks like I’m at 10.6Volts .
  2. Mar 9, 2019 at 2:25 PM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Well at the moment it is. Jump it and use a multimeter and see what it reads. Should go to 13.5-14.1 and then settle.
    Twinky likes this.
  3. Mar 9, 2019 at 2:28 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have heard the batteries suck.
    Otaku4life69 likes this.
  4. Mar 9, 2019 at 2:53 PM
    ProtoJ
    I just noticed one of the back doors wasn't closed all the way! So can I just jump it and drive it around for 15 minutes to recharge it or do I need a new battery?
  5. Mar 9, 2019 at 3:32 PM
    ProtoJ
    Thanks for the replies. I gotta drive soon...so I guess I need to pick up a battery today. None of the stores locally seem to have 2018 Tundra 5.7 batteries in their battery selectors...I assume I can use one for another year since 2018 does not seem to exist. Lots of Optima battery choices available locally. Does anyone use an Optima 35? Looks small....but that's all Im finding.
    Black Wolf likes this.
  6. Mar 9, 2019 at 3:38 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    You could also have Toyota test the battery. My local dealer just replaced the battery on my ‘16 under warranty because it was not holding a charge. (Not as good as other batteries but free).
  7. Mar 9, 2019 at 3:40 PM
    ProtoJ
    I don't live anywhere near the dealer...and its a Saturday. So I need to find something local......just confused on the size since none of the battery selectors have the 2018 in their program or give too many results for other years. The optima looks so much smaller...but is taller I guess. The amps match the stock one.
  8. Mar 9, 2019 at 3:43 PM
    surfnmoto2
    surfnmoto2 New Member
    Lee
    What city are you in? It's possible a Tundra member here could assist you.
    Good luck.
  9. Mar 9, 2019 at 3:50 PM
    ProtoJ
    Top is my stock....bottom is the optima 35 that I can buy in town right now. Does anyone see any issues?
  10. Mar 9, 2019 at 3:52 PM
    15whtrd
    15whtrd Mr. Blonde
    From what I’ve heard after starting your truck it typically takes the alternator 20 minutes to fully charge your battery back to full. So you have a dead battery. I would either use a trickle charger or jumpstart it and be on my way. But I wouldn’t turn it off until I know I can either jump start it again or get a new battery and have the alternator tested. If it restarts no problem you are probably fine, The fact that you left your door open could be why it died.
    NewImprovedRon, joonbug and Finch like this.
  11. Mar 9, 2019 at 3:53 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t trust Optima anymore. They are not what they used to be in my experience. If I’m going to go with a typical battery it will probably be a interstate, diehard or something with a good warranty. Since your truck is so new you could even call Toyota Care and have them come fix you up for free.
  12. Mar 9, 2019 at 3:54 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    The Optima is a good battery. If the listing doesn’t show an 18, then check 16 or 17, going to be the same. The more cold cranking amps the better. Optima batteries pack more power in a smaller size. Use stock dimensions for the battery box and hold down, and install the most powerful one (Optima) that you can. Buy a Battery Tender off Amazon and keep it handy for situations like this. Some battery tenders have the capability to jump start. Good luck.
  13. Mar 9, 2019 at 3:55 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    If you gotta roll, then you gotta roll. But @15whtrd's "call Toyota Care" suggestion is a good one.
    iHacker and 15whtrd like this.
  14. Mar 9, 2019 at 3:59 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    One of those cases where everyone’s experience will vary, 2014 here just rolled 68k miles on stock battery. I’m assuming as long as you replace it with a group 27F battery you’ll be fine, more than likely if my battery finally goes out I’ll stick with stock again.
    Filthy13 likes this.
  15. Mar 9, 2019 at 4:01 PM
    15whtrd
    15whtrd Mr. Blonde
    Yup. My stock battery is still going strong. Knock on wood. I will probably get one from Costco when the time comes.
    YardBird and Samoan Thor[QUOTED] like this.
  16. Mar 9, 2019 at 4:12 PM
    Go to a batteries plus, get a good AGM battery. I don’t do Optima batteries either.
    NewImprovedRon, BTBAKER, B737 and 2 others like this.
  17. Mar 9, 2019 at 4:40 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Northstar 27f
    NewImprovedRon, Filthy13 and YardBird like this.
  18. Mar 9, 2019 at 5:04 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    2017 battery is the same as the 18.
  19. Mar 9, 2019 at 5:04 PM
    ProtoJ
    492EEDAA-D538-4BD3-8134-F77D27C4F5ED.jpg It would not take a jump. All town has was junk or optima 35. Now I can either take my core back or have Toyota warranty the old one as a spare.
    Black Wolf and KnuckleHD like this.
  20. Mar 9, 2019 at 5:46 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    Get a Northstar or Odyssey. Screw those Toyota batteries. Mine died at 37k only 2 years old.
  21. Mar 9, 2019 at 5:53 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    OEM batteries are junk. Mine went out after 6 months... Toyota replaces with a true start this time.
    ProtoJ[OP] likes this.
  22. Mar 9, 2019 at 6:21 PM
    TXTundra2722
    2015 Black Tundra
    I ran Optima for years in my jeep and had zero issues.
  23. Mar 9, 2019 at 6:36 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Alternators are not designed to recharge a low battery. Need to put a charger on it.
  24. Mar 9, 2019 at 6:43 PM
    Optima D27F....
  25. Mar 9, 2019 at 6:52 PM
    My Optima D27F is doing just fine. After Optima line relocated to Mexico there were QA issues at first. Not unreasonable considering the whole manufacturing line was moved. I know this because the Johnson Control Optima battery manufacturing line used to be right here in Aurora, CO up to the move down south and was one of our larger calibration clients. Lot's of disgruntled employees also posted a lot of crap about the move and after. Can't blame them but that was several years ago. lol. Does it suck being made south of the border?? Sure, just like it sucks with all the big 3 trucks being built down there. No doubt there were issues when that move was made. Lots of great AGM's out there....and I've heard right here on the forum how bad the new OEM batteries are.
    15whtrd[QUOTED] likes this.
  26. Mar 9, 2019 at 7:10 PM
    ProtoJ
    I’m just glad I found a battery in town ......my truck was parked halfway in the garage while I was doing stuff and I really didn’t want to leave my garage open all night!
    15whtrd and Black Wolf like this.
  27. Mar 9, 2019 at 7:20 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s good to know. Because quite a few years back (15 ish) they weren’t lasting me more than a couple of years. This was on a 95 turbo Eclipse. Some of that may have been due to some electrical issues with the car. The car sat a lot and the battery would be dead after a couple of weeks. It would not hold charge afterwards. I think I hated them more out of frustration LOL maybe I will try one again. I was thinking of north star from Cosco next time though.
  28. Mar 9, 2019 at 7:24 PM
    Northstars are a win win battery...:thumbsup:
  29. Mar 9, 2019 at 7:28 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Any suggestions on a bigger size battery for a 3rd gen? I was thinking of going Odyssey batteries.
  30. Mar 9, 2019 at 7:30 PM
    I think Odyssey has a new larger group size out with super CA/CCAs. Heard about it here somewhere.
    porkitt[QUOTED] likes this.
