Is this connector from tundra?
Discussion in 'General Tundra Discussion' started by mi4, Jun 27, 2021.
  1. Jun 27, 2021 at 8:38 PM
    mi4
    mi4 [OP] New Member
    I power washed my truck on my driveway and found this connector where the truck was parked for two or three hours after the truck was moved. Pretty sure it was not there before since it is right under my security camera. Googled and it seems to be a mc4 connector for solar panel. But how it got underneath my truck is a puzzle to me. Is such a kind of connector used by Tundra?
  2. Jun 27, 2021 at 8:49 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    That’s a transmission cooler from a 2019. Is yours a 2019?
    Fearthisbeard, BTBAKER, Oey12 and 6 others like this.
  3. Jun 27, 2021 at 8:56 PM
    mi4
    mi4 [OP] New Member
    Yes, it is a 2019. So maybe somehow I broke it when using power washer? Where should it be located?
  4. Jun 27, 2021 at 9:00 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Damn. Good eye, dude.
    2mchfun likes this.
  5. Jun 27, 2021 at 9:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That looks like Military grade to me, call in the robots.
    Saltyhero13 and ToyoMafia like this.
  6. Jun 28, 2021 at 3:07 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Are you sure it isn’t from your pressure washer?
    prevent likes this.
  7. Jun 28, 2021 at 3:31 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It's too big. You should need a SEM at minimum to see it.
    Saltyhero13 likes this.
  8. Jun 28, 2021 at 4:52 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    I'm gonna go with this one,
    SPP
  9. Jun 28, 2021 at 5:03 AM
    Looks like it came out of the pressure washer wand.
  10. Jun 28, 2021 at 6:06 AM
    2mchfun
    There should be a small stainless steel tubular spacer about 1/4" long that would have also fallen off of your truck at the same time. You really need to locate that before you proceed.
  11. Jun 28, 2021 at 6:13 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Make sure you get your load on it before you disconnect.
    Saltyhero13, 2mchfun and hagrid like this.
  12. Jun 28, 2021 at 6:14 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    LOL!!
    ToyoMafia likes this.
  13. Jun 28, 2021 at 6:35 AM
    mi4
    mi4 [OP] New Member
  14. Jun 28, 2021 at 6:38 AM
    2mchfun
    Have you verified that you don't have the solar powered transmission cooler?
    Gravy, prevent, 1lowlife and 2 others like this.
  15. Jun 28, 2021 at 7:23 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    LOL!!!
  16. Jun 28, 2021 at 7:49 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    This is the connector used for cooling the transmission with your pressure washer when under a full load. It use the battery operated solar panel to power the thermostat puck located on the transmission. DO NOT DISCONNECT UNDER LOAD!
    hagrid and 2mchfun like this.
  17. Jun 28, 2021 at 8:19 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes, but did it snap nipples?
    hagrid and ToyoMafia like this.
  18. Jun 28, 2021 at 8:29 AM
    2mchfun
    Probably only the plastic nipple on the passenger exhaust header. Mine broke off while I was using a car wash wand applying the 3 layer clear coat protection to keep my puck shining.
    RainMan_PNW[QUOTED] likes this.
  19. Jun 28, 2021 at 8:37 AM
    crewmaxlmt
    scott
    Plastic nipple? Mine fell off when going down the freeway. This was due to the exhaust manifold melting. I just use PVC pipe now, well CPVC because of the high heat.
    RainMan_PNW likes this.
  20. Jun 28, 2021 at 8:40 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Yes, that's a solar connector.
    prevent, 15whtrd and Saltyhero13 like this.
  21. Jun 28, 2021 at 8:43 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    You filthy sick...
    ...I like it
  22. Jun 28, 2021 at 8:45 AM
    2mchfun
    Heat? Stop turning the key on then you can run pvc.
  23. Jun 28, 2021 at 8:50 AM
    shawn474
    MoCo, Maryland
    Maybe it bounced up from the road and was in your undercarriage - fell out while washing the truck. Good to know it isn't anything truck related
    2mchfun and NewImprovedRon like this.
  24. Jun 28, 2021 at 9:03 AM
    2mchfun
    Also a great prop for giving the newbie a warm and quite funny welcoming!!!! Thanks for your honesty, poor guy might have to climb up a ladder and locate the real issue. Wind and or Sun might have affected his system.
  25. Jun 28, 2021 at 9:04 AM
    Kung
    KG, VA
    2mchfun, hagrid and ToyoMafia[QUOTED] like this.
  26. Jun 28, 2021 at 4:09 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    @mi4 just took the opportunity for a good joke…(not of you) hope I didn’t offend. It Probably fell off your truck but not a piece of it for sure.
    2mchfun likes this.
  27. Jun 28, 2021 at 6:47 PM
    crewmaxlmt
    scott
    So you are saying that we have to stop?
  28. Jun 28, 2021 at 7:30 PM
    ToyoMafia
    Magic carpet.
    Nope not gonna happen.
  29. Jun 28, 2021 at 7:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is this PHM reincarnated?
    N84434 and Tundra2 like this.
  30. Jun 28, 2021 at 7:40 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    It’s not off your truck so don’t sweat it.
