Is this Brake kit legit?
Discussion in '1st Gen Tundras (2000-2006)' started by buccirj, Jan 10, 2022.
  1. Jan 10, 2022 at 4:14 PM
    buccirj
    buccirj [OP] New Member
    2002 Tundra 4.7L V8 TRD SR5 4WD ext cab
    2.5" Rough Country Susp. Kit N3 Struts & Shocks
  2. Jan 10, 2022 at 4:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The Powerstop kit is legit, yes. I have this on my truck.
    If you are buying calipers too, I would recommend getting the KC2324-36. Those are 13WL calipers which is a little bit of an "upgrade".
    The part number you mentioned, KC2323-36, is for S13WE calipers. Your truck might have come with those stock. It's common for people that had S13WE calipers to upgrade to the 13WL.
    Darkness and buccirj[OP] like this.
  3. Jan 10, 2022 at 4:27 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    How has this kit been holding up for you? Did you do any upgrades on the rear drums?
  4. Jan 10, 2022 at 4:30 PM
    des2mtn
    SW
    Tonto cover
    Completely fine without issue going on like two years? Pads have plenty of life and are better than any I've used in the past.
    Upgrades on the rear drums? Yeah. I got rid of them completely and I have rear discs that also use a Powerstop Z36 kit.
    Darkness likes this.
  5. Jan 10, 2022 at 4:43 PM
    buccirj
    How can I tell which calipers I have? I read somewhere it might be stamped on it, haven't gotten under to look yet as I've been working other issues since I bought it few months back. Mine is the access SR5 4.7L 4x4 without the off-road package, I think.
  6. Jan 10, 2022 at 4:46 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Used those brake pads on car quest premium rotors (cheaper due to shipping). Work great. Lots of opinions on this in many threads.
  7. Jan 10, 2022 at 4:50 PM
    des2mtn
    SW
    Tonto cover
    It's a number that's cast/ stamped onto it like you said. It should be in between the where the brake line goes in and the bleeder valve.
    To change from S13WE to 13WL though, the only limiting factor is the wheels. If you're on OEM Toyota wheels, they'll fit. They're a larger caliper that sometimes do not fit aftermarket 16" wheels. There's quite a few people on here that made this change I'm suggesting and now is the time.
  8. Jan 10, 2022 at 4:50 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its stamped on the caliper on the inner side if that makes sense. Here mine says 13wl above the mounting bolt ear.
    des2mtn likes this.
  9. Jan 10, 2022 at 4:57 PM
    buccirj
    Alright cool. I'll take a look. I am running a 2.5" Roughcountry lift with 285/75R16 KM3 mounted on 16x8 wheels with a -10mm offset. Should fit...I hope.
  10. Jan 10, 2022 at 4:59 PM
    buccirj
    Depending on which caliper it has oem, do I want to stay with the same type of caliper then? I've done a BBK on my '08 M3 with APracing and there was a template to use to ensure clearance. So this will be my second brake mod but bit unfamiliar with the Tundra as it's new to me.
  11. Jan 10, 2022 at 5:01 PM
    buccirj
  12. Jan 10, 2022 at 5:02 PM
    des2mtn
    SW
    Tonto cover
    They clear my 16x8 Methods with 0 offset.
  13. Jan 10, 2022 at 5:10 PM
    buccirj
    Sorry for the giant snip-it but I used this calculator when I was picking my tire/wheel combo. I'm not sure what the stock wheel offset is but looking it up, says 10 -10 so somewhere in between I guess. But if so, I'm guessing it'll clear also.
  14. Jan 10, 2022 at 5:38 PM
    des2mtn
    SW
    Tonto cover
    I'm willing to bet it'll clear your wheels too. Worst case scenario if they don't, they might let you return and swap for the other part number.
    buccirj[OP] likes this.
