Is this a throttle cut or some engine hesitation?
Discussion in '2nd Gen Tundras (2007-2013)' started by MarcoD, Apr 12, 2023.
  1. Apr 12, 2023 at 10:16 AM
    MarcoD
    MarcoD [OP] New Member
    Dallas, TX
    2010 Silver Tundra SR5 5.7L 4x4 CM
    So today I’m driving my truck around town. I made a tight right turn due to traffic and spacing. My traction control kicked in and felt like the throttle was being cut and (there was rocks and a little sand). Then I’m the first at the light and took off once it turned green. As I was going through the intersection I felt a slight hiccup/hesitation but this time the traction control light didn’t come on. Im trying to figure out if it was a throttle cut or actual hesitation.
  2. Apr 12, 2023 at 10:20 AM
    MarcoD
    Dallas, TX
    By the way, everything went back to normal after I went through the intersection. I’m trying to figure out possibilities of it acting weird when going through the intersection
  3. Apr 12, 2023 at 10:22 AM
    MarcoD
    Dallas, TX
    It seems to have this issue when going through a bumpy intersection
  4. Apr 12, 2023 at 10:31 AM
    Likely traction control related
    MarcoD[OP] likes this.
  5. Apr 12, 2023 at 10:33 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Sounds about right for a traction control situation. Very brief activations may not have the TC light come on.
    TC activating in a rough intersection may indicate that it’s time for new shocks, depending on how rough it really is, and how hard you’re pushing it. Overinflated, unevenly inflated, or worn tires won’t help either.
  6. Apr 13, 2023 at 8:59 AM
    binary101
    binary101 New Member
    07 Tundra 4.7L
    My 07 Tundra did something similar once about 2 years ago and hasn't happened since.
  7. Apr 13, 2023 at 9:18 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Is the truck stock height/tires or lifted?
  8. Apr 13, 2023 at 9:41 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Traction control will cut throttle, sometimes until 2-3 seconds after the slipping stops if it's a lot of spin
