Is there any way to level my head lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Jan 10, 2019.
  1. Jan 10, 2019 at 7:14 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I have the most basic head lamp in the 2016 tundra sr5. The amber light is always on.
    I had my tucked lifted a bit and now my light point way down. Any information will ge greatly appreciated thanks in advance
  2. Jan 10, 2019 at 7:43 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    No adjusting wheel on the lower left side of the dash? I thought they all had the manual headlight adjuster.
    040Tundra likes this.
  3. Jan 10, 2019 at 7:45 PM
    War Machine
    War Machine SSEM # 5 3MW
    No adjustment knob in your cab?
  4. Jan 10, 2019 at 7:45 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    +1
  5. Jan 10, 2019 at 7:56 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
  6. Jan 10, 2019 at 10:58 PM
    Erick
    Erick
    Thornton Colorado.
    Omg
    .. I'm freaking retarded. Haha. I took em out to look for knobs and everything. I had now idea these trucks had the feature.
  7. Jan 10, 2019 at 11:39 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Your not retarded!
  8. Jan 11, 2019 at 3:53 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    OP I'm confused. If you lifted your truck wouldn't the lights shine higher vs lower?
    Black Wolf and OR18TRD like this.
  9. Jan 11, 2019 at 4:13 AM
    This thread is quite confusing. If your headlights are shining low...the adjustments are on the backside of the headlamp itself not on the dash..:confused: Unless you have a 2014 and up which you do. I'm assuming your headlamps have the motorised adjustment?
  10. Jan 11, 2019 at 4:22 AM
    Woodtickmp
    Woodtickmp Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
    I have the level adjust in the cab with my 2010.
  11. Jan 11, 2019 at 4:25 AM
    timsp8
    NY
    Even ones with the level adjustment in the cab have a bolt on the back of the headlight itself to raise and lower. Also lets you adjust one if they aren’t even.
    15whtrd likes this.
  12. Jan 11, 2019 at 4:32 AM
    Woodtickmp
    Mathew
    west bend WI
    Do you know exactly where it is, because i have been trying to find out how to bring the headlights up a bit
  13. Jan 11, 2019 at 4:35 AM
    timsp8
    NY
    I’d have to look. On my old 2010 there was a bolt either 8mm or 10mm that was on the back. Easier to find and get to on passenger side without battery in the way.
  14. Jan 11, 2019 at 4:48 AM
    timsp8
    NY
    Black Wolf and 15whtrd like this.
