Is there a way to turn the warning off on the screen?
Discussion in '2.5 Gen Tundras (2014-2021)' started by OddJack, Jun 19, 2024.
  1. Jun 19, 2024 at 11:55 AM
    OddJack
    OddJack [OP] New Member
    Dino
    My precollision system is malfunctioning and I will get to fix it later. Is there a way to have the messages on the screen not show up? I cant see the speed. It just showing the warnings.
    2018 Tundra Sr5
  2. Jun 19, 2024 at 12:07 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Isn’t there an ok button (or equivalent) on steering wheel that acknowledges the message? It should go away.
  3. Jun 19, 2024 at 12:11 PM
    RobertD
    Robert
    DFW, Texas
    At least you still have the analog speedometer.
    I think you have to go to the warning screen every time you start the vehicle and acknowledge/clear it.
  4. Jun 19, 2024 at 3:34 PM
    OddJack
    Dino
    No I dont see any acknowledge option
  5. Jun 19, 2024 at 4:16 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    On my 2018 I turn the STUPID PCS off every single time I start the truck. I asked the dealer if he could permanently disable it with Techstream and he said they couldn't. So, turning it off is a part of my startup routine.
  6. Jun 19, 2024 at 4:32 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Pretty sure it’s the button on wheel with the arrow. Like a return symbol.
  7. Jun 19, 2024 at 5:53 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    unplug the sensor near front of hood and top of grill?
    Is that the sensor that is tweaking?
  8. Jun 19, 2024 at 6:20 PM
    OddJack
    Dino
    I dont remember if I tried the Return button to acknowledge, I will try that.
    I unplugged the sensor, it doesnt go away. I even put on a new sensor, I disconnect the battery for 30 mints.
    Anyone knows if the distance sensor is somehow connected to trailer brake system? Cuz that one is coming up too.
    Pig Rig likes this.
  9. Jun 20, 2024 at 10:30 PM
    OddJack
    Dino
    Return button solves the problem only for few seconds
  10. Jun 21, 2024 at 3:29 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Yep seems like all the warnings for Toyota are like that. Yes I see the front sensor is limited due to snow. No I don’t need to know that every 3-5 seconds for the entire winter.
    OddJack[QUOTED][OP] likes this.
  11. Jun 22, 2024 at 12:31 PM
    OddJack
    Dino
    They won, paid them an arm and a leg to fix it.
    Trailer brake malfunction, autoheadlight malfunction, PCS malfunction, LDS malfunction... was all fixed by, according to them, just replacing the angle position sensor in steering wheel and calibrating the sensor behind the grill.
    Dropped it off Friday, picked it up today. Clean and fast service though. They even sent me a video of the truck.
  12. Jun 22, 2024 at 12:59 PM
    Did the errors just appear or was something done to the truck? I'm betting that the sensor in the steering wheel was good. They just cleared codes and reset the system. Toyota needs to sell parts to make money. I just went through this a few months ago with our 4Runner. I had a PCS code because I turned the steering wheel while I has it on jack stands. It would not clear regardless of what I did. Took it in and they tried to tell me that an airbag sensor in the steering wheel failed and was not covered under warrant. They said it was $1200 and backordered. They cleared the code and said it will come back. It never did.
