Is there a way to reset Engine Immobilizer?
Discussion in '2.5 Gen Tundras (2014-2021)' started by taylorjt37, Sep 3, 2018.
  1. Sep 3, 2018 at 2:52 PM
    taylorjt37
    taylorjt37 [OP] New Member
    Not sure how it was activated but the Engine Immobilizer activated the Anti-theft system on my 2014 Tundra and I cannot start my truck. Can I pull a fuse to reset? I've tried everything I've found online but nothing has worked yet. Should I have it towed to a mechanic? The dealership said they would need to run a scan so I would have to tow it in. I called a local locksmith and they can come out and program keys for me but will that reset the Anti-Theft system? Any suggestions/help would be greatly appreciated!
  2. Sep 3, 2018 at 11:06 PM
    DantheMan
    DantheMan 2018 Platinum Pro 4X4 Crewmax
    San Diego
    2018 Tundra 4X4 Platinum Pro Crewmax
    Toytec 3” Level ~ BFG KO2’s ~ Method Wheels ~ TRD Performance Dual Exhaust ~ TRD Performance Air Intake ~ TRD Rear Sway Bar ~ TRD Shift Knob/Radiator & Oil Caps ~ Color Matched Handles & Caps ~ Color Matched Fender Flares ~ Blacked out Emblems w/ Custom TRD Rock Warrior Decals ~ Bakflip MX4 Tonneau ~ Bedrug ~ KBVoodoo Rack ~ Alpine Halo9 Head Unit ~ Ram Mount System ~ Short Antenna ~ Mounted Hi-Lift/Krazy Beaver/Rotomax/Fiskers ~ Engel Bed Fridge/Freezer ~ Tepui Grand Sabanna Roof Top Tent w/ Custom Mattress
    Checking to see if you found a solution? Same thing happened to me with my brand new Tundra and Im stranded in a National Park with locksmiths and tow trucks far away
