Is there a way to remove the seatbelt chime?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AleutianTaco, Mar 17, 2023.
  1. Mar 17, 2023 at 10:52 PM
    AleutianTaco
    AleutianTaco [OP] New Member
    Is there a way to remove the seatbelt chime on a 2021 Tundra? You know that ding ding ding sound when the seatbelt is not buckled.
    Off road use only.
    I have a 2022 Tacoma and while having it tuned, the guy was able to turn off the chimer with his computer. Haven't been able to get ahold of him to see if he can do it on the Tundra.
    Tripleconpanna likes this.
  2. Mar 17, 2023 at 11:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yes, with techstream it can be removed. Had mine's deleted on the driver side at the dealer
    joonbug likes this.
  3. Mar 17, 2023 at 11:27 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes, the next time you are at the dealer tell them you want that feature disabled, and they can do that for you....
    Some dealers will tell you they can't or won't due to liability, but that is bullshit; ask to speak to someone like the SVC Manager or take it to another dealer... If they ask tell them you want to be able to pull the seat belt off in parking lots, drive thrus, etc... w/o the stupid thing beeping constantly.
    I have a '21 Pro and pages 565-573 of the Owner's Manual is section 8-2 (Customization); within this section is a list of features that can be customized; column 1 is features that can be changed by you in the Multi-Info Display; column 2 is features that can be changed by you in the MultiMedia Sytem; and column 3 is features that can be changed by the dealer.... For me, page 572 has a section on Seat Belt Reminder Buzzer w/dashes in columns 1 and 2, and an 'O' in column 3 which means the buzzer can be customized to an "off" setting by the dealer.
    It's a feature of your vehicle, so they should honor it w/o too much grief.
    Good luck!!!
    Pot Hole and WFD473 like this.
  4. Mar 17, 2023 at 11:27 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
  5. Mar 17, 2023 at 11:37 PM
    AleutianTaco
  6. Mar 17, 2023 at 11:43 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Might not be the easiest way after all. Just ask your dealer to remove it. I had it done when I had the truck in for one of it's first free oil changes, cost nothing
    joonbug and Tripleconpanna like this.
  7. Mar 17, 2023 at 11:47 PM
    Musicmasterd12
    Southern Louisiana
    it comes with a free one month subscription. Do what you need to do with it then just cancel the subscription. If you ever need it again the fee is $10/month and you can do the same thing subscribe and cancel
    MUCH easier than getting the Techstream to work at home. And less headache than trying to get the local dealer to do it. Mine wanted to charge me an hours labor to do it…f**k that!!!
    But to each there own. Goodluck
  8. Mar 17, 2023 at 11:50 PM
    AleutianTaco
    Yeah I suppose it is worth it. Local Toyota dealer is awful. So bad that I bought from the lower 48 and shipped the truck to Alaska instead of deal with them again
    Cthulhu and BravoDeltaRomeo like this.
  9. Mar 18, 2023 at 1:39 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Could use those pet harness clips. Just latch it in when you want it to turn off, take it out when you are back on the street.
  10. Mar 19, 2023 at 4:24 PM
    GatorBodine
    GatorBodine New Member
    Just a use a seatbelt extender. It clips into the button latch portion of the seatbelt. Fools the vehicle that the seatbelt is actually buckled. Can still use the seatbelt as you wish.
  11. Mar 19, 2023 at 4:46 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    For anyone who cares to know:
    The audible alarm or tone is actually emitted by the insturment cluster. Reasons why the the tone sounds likes it’s coming from the dash. The “speaker” is in the back of the instrument cluster. It knows (via the communication network) if the seatbelt is buckled or not.
    A simple message on the network via the OBD port tells the cluster to no longer make a sound when the seatbelt is unbuckled.
    Techstream has the ability to communicate with the truck and send the message. Carista and some others have cloned the message from Techstream and can do it as well.
    Its a flew clicks of a button to turn it off. The hard part is getting software and cable that can “talk” to the truck
    HulkSmurf14, sonofdad and Wynnded like this.
  12. Mar 19, 2023 at 4:53 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    To add to this you could simply keep a “buckle” in the seatbelt switch to fool it into thinking the belt is on 24/7
    OR you could also go underneath the seat and splice the two wires to the buckle switch together. This would also fool the truck into thinking the buckle is in 24/7. I have not tried this and it’s assuming the truck isn’t smart enough to look for this. IE if it sees the seatbelt on 24/7 before startup ect it might throw a trouble code but I doubt it’s that smart to look for that kind of thing.
    HulkSmurf14 likes this.
  13. Mar 19, 2023 at 4:56 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Additional FYI for the general masses, the sound portion of the notification can be silenced, but the red indicator on the dash cannot (using conventional methods, but, the LED can always be unsoldered if you're so motivated). I think that access to disabling the sound is dependent upon the dash cluster the vehicle is equipped with. I upgraded from my original cluster to one from a Limited and gained access to that specific setting as well as others that required Techstream or some other OBDII device via the cluster.
    Jeff_5_7[QUOTED] likes this.
  14. Mar 19, 2023 at 7:41 PM
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
  15. Mar 21, 2023 at 4:27 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I just fasten my seat belt behind me at the first gate when I get to the ranch I hunt on.
  16. Mar 22, 2023 at 9:15 AM
    seydou
    seydou Distinguished Member
  17. Mar 22, 2023 at 9:19 AM
    PermaFrostTRD
    Northern NY
    Is my truck the only one that stops chiming after like 15-20 seconds anyway? After that steady stream of chimes?
  18. Mar 22, 2023 at 9:28 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My driver side chime is turned off, but I can share that my passenger side behaves this way.
    PermaFrostTRD[QUOTED] likes this.
  19. Mar 22, 2023 at 10:21 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    mine stops after that amount of time too
  20. Mar 22, 2023 at 10:41 AM
    seydou
    Mine does as well, but if you are in and out of the vehicle a lot, it is nice not to have to listen to it.
    PermaFrostTRD likes this.
  21. Mar 22, 2023 at 1:08 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I paid like $6 for one of those bottle opener things to plug in when the pup is rolling shotgun.
  22. Mar 22, 2023 at 1:54 PM
    Rocko9999
    Rocko9999 New Member
    What else can you do with that?
  23. Mar 22, 2023 at 4:52 PM
    Musicmasterd12
    Southern Louisiana
    there was a few different settings, can’t remember them all
    main thing was seat belt chime and light sensitivity of auto headlights for me. Think there was something if you had auto ac, adjusting the dinging volume when key is in ignition and door open, and a couple other little things
    I was able to use it on my wife’s pathfinder as well to change some settings. So each car is a little different
    Rocko9999[QUOTED] likes this.
  24. Mar 22, 2023 at 4:54 PM
    Musicmasterd12
    Southern Louisiana
  25. Mar 23, 2023 at 9:04 AM
    Rocko9999
    Thank you.
    Dings & Warnings
    Seat belt warning ding (driver)
    Enabled / Disabled
    Seat belt warning ding (front passenger)
    Enabled / Disabled
    Ding when headlights are left on
    Yes / No
    Key-in-ignition ding sound
    Slow / Medium / Fast
    Driver Assist
    Pre-Collision System (PCS) sensitivity: remember last state
    Enabled / Disabled
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    Far / Remember last distance
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    Heater & A/C
    Open vents to outside air when ignition is turned off
    Yes / No
    Instruments: Displays & Nav
    Instrument lights dimming sensitivity
    Darkest / Darker / Normal / Lighter / Lightest
    Instrument lights restoring sensitivity
    Display odometer after ignition is turned off for…
    30 seconds / 1 minute / 10 minutes / Off
    Microphone sensitivity
    1 - 11
    Lights: Automatic
    Auto headlights activation threshold
    Lights: Exterior
    Daytime running lights
    On / Off
    Lane-change turn signal auto-flasher count
    Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
    Coming-home lights duration
    Off / 30 seconds / 60 seconds / 90 seconds
    Lights: Interior
    Interior light control
    Enabled / Disabled
    Turn on interior lights when you shut off engine
    Yes / No
    Turn on interior lights when you unlock doors
    Yes / No
    Turn on interior lights when smart key in range
    Yes / No
    Dim interior lights after…
    7 seconds / 15 seconds / 30 seconds
    Locking: Automatic
    Wireless door locking
    Enabled / Disabled
    Auto-lock all doors
    Disabled / When shifting into gear / When vehicle starts moving
    Auto-unlock all doors
    Disabled / When shifting into park (P) / When driver's door is opened
    Re-lock doors automatically if you unlock, but don't open a door
    Yes / No
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 seconds / 60 seconds / 120 seconds
    Locking: Beep & Blink
    Beep when locking/unlocking with remote
    Yes / No
    Volume of beep when locking/unlocking with remote
    Off / 1 / 2 / 3 / 4 / 5 / 6 / Max
    Blink turn signals when locking/unlocking with remote
    Yes / No
    Locking: Doors & Alarm
    Unlock doors via remote
    Driver's door on 1st press, all on 2nd / All doors on 1st press
    Unlock doors via physical key
    Allow locking when a door is still open
    On / Off
    Warn (beep) when door can't be locked because it's still open
    Yes / No
    Windows & Sunroof
    Open windows and sunroof by turning and holding key in door lock
    On / Off
    Close windows and sunroof by turning and holding key in door lock
    On / Off
    Other
    Panic function on remote
    Enabled / Disabled
    sonofdad likes this.
