Is there a reason to bypass the speed sense and park brake for the Nav
Discussion in 'Audio & Video' started by billru, Mar 18, 2019.
  1. Mar 18, 2019 at 4:36 PM
    billru
    billru [OP] New Member
    2019 Tundra Crewmax Limited
    For the navigation bypass I know you install a switch on the spd wire (Pin 17), I have heard of people installing a switch on the park brake circuit also, why are they doing the park brake.
  2. Mar 18, 2019 at 4:39 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  3. Mar 18, 2019 at 5:00 PM
    Jrfor0
    Jrfor0 New Member
    James
  4. Mar 18, 2019 at 5:54 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Depends on the headunit but some require the parking brake to be on to play video.
  5. Mar 18, 2019 at 5:54 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Rear LED, inside LED
    Almost all Nav systems require you to be parked in order to use it. That's why many people put in a bypass on that. Some even require the e-brake to be press before it allows you to change anything. That's why most do this to prevent anything else from coming up, hope this helps.
  6. Mar 18, 2019 at 7:27 PM
    billru
    Thanks for all the replies, I was curious cause I did the Nav mod (toggle switch on Pin 17 of the spd wire) on my 2016 Tundra and all worked fine so I was just checking on the reason why some people were also doing the park brake.
  7. Apr 10, 2020 at 9:12 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Do you happen to know which wire (pin#) is for the parking brake?
