Is there a Mileage increase using K&N Cold Air Intake
Discussion in '2nd Gen Tundras (2007-2013)' started by LennyFL, Nov 19, 2019.
  1. Nov 19, 2019 at 2:46 PM
    LennyFL
    LennyFL [OP] New Member
    New to me 2007 with 59,600 miles
    I was looking at K&N PERFORMANCE AIR INTAKE SYSTEM they talk about increased mileage and horsepower.
    Has anyone tried it? what were the results?
    thanks,
    Lenny
  2. Nov 19, 2019 at 2:53 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Many have tried, negligible gains if any.
    Google SABM, it may have marginal gains.
    Nothing out there except Super Charger that will improve mileage.
    15whtrd and Rex Kramer like this.
  3. Nov 19, 2019 at 3:05 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I don’t think they do. My theory is, and it may be wrong, that is if you are driving easy, you are already using a minimal amount of air that the stock setup can easily provide. If you are getting on it and pulling air beyond the capacity of the stock intake, you are getting more air and more air needs more gas to maintain air/fuel ratio. Even if you are getting colder and denser air, the engine will always try to maintain the proper air/fuel ratio. There are probably a million other variables that come into play, but that’s the mindset I have in regards to MPG. I think they are designed with other attributes in mind.
    10TundraSR5, bvia, WFD473 and 3 others like this.
  4. Nov 19, 2019 at 3:24 PM
    They do not. The best option is to do the SABM and drop in a K&N or AFE Pro S dry filter. The stock intake is a CAI so dont give in to the aftermarket cold air kits.
    10TundraSR5, 15whtrd and BestGen like this.
  5. Nov 19, 2019 at 5:27 PM
    Blue Thunder
    Washington
    Exactly. The stock air box would have to be severely restricted to make any difference here. With the MPG and HP wars taking place, no OEM has ignored the intake for a long time. So “more air” just gets more fuel to maintain the ratio and you see zero gains. If you truly are seeing real-world results (and I seriously doubt anyone that claims them), you’re probably not filtering the air good enough.
    Aerindel and focal[QUOTED] like this.
  6. Nov 19, 2019 at 5:44 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I had one on a 5.3l gm v8. The only increase I found was the increased noise level. It made a roaring sound when the engine was under an increased load (annoying).
    snivilous likes this.
  7. Nov 19, 2019 at 6:21 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    At one time there was a class action suit against K&N for false claims. Never heard how it was settled and don't care because I would never fall for their marketing BS.
  8. Nov 19, 2019 at 6:43 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    K&N just save your money and buy a oil free drop in washable filter thought the samething it was a waste of money.
  9. Nov 20, 2019 at 7:15 AM
    559WeekendWarrior
    559WeekendWarrior New Member
    Menger
    2010 SR5 5.7L PreFlex Warrior
    Custom Build Tubing 3.5 with 3.7 Trd Intake 2014-2019 with Turbo Head Shield Air Filter, Jet Performance MAF, Throttle Body Spacer With Econoaid Throttle Body Booster Gasket. Exhaust 2.5 Cherry Bomb 7841 single with dual Side frame exit or in front of the rear passenger tire. Pedal Commander plug in play for the gas pedal. Last is leveling kit 3-1 front and rear with 32-33 MT tires.
    Custom your own like I've did, or get the trd intake because the mount you spend on a k&n with just a hair more you can get the trd. It depends on how you like your intake to sound yes they all sound the same but you may understand later.
  10. Nov 20, 2019 at 8:00 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    You only get one .
    Horsepower OR Mileage .
    Never both together.
    Trooper2 and focal like this.
  11. Nov 21, 2019 at 7:36 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Ryan
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    So is it worth it to go all out and get the TRD intake or is dropping a K&N filter in the stock air box going to give you the same results? Thanks
    10TundraSR5 likes this.
  12. Nov 21, 2019 at 7:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Just make sure your air filter is clean and keep your foot out of it. Also basic maintenance up to par.
    WFD473 and Blueknights75 like this.
  13. Nov 21, 2019 at 7:51 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    K&N us a good way to hone your cylinders. Never use them if you want your engine to last a long time. There is a reason they flow well given the surface area, they let a bunch of crap through them.
    Paper or oiled foam is the only way to go.
  14. Nov 21, 2019 at 7:57 PM
    Been using K&N's since the early 70's on all my rides and never had any issues. Ever....
    10TundraSR5, 15whtrd and ryanryan34 like this.
  15. Nov 21, 2019 at 7:58 PM
    Jengel451
    The Bitterroot, MT
    Drive in a silty environment and check your intake. Never ever ever again.
  16. Nov 21, 2019 at 7:59 PM
    I have. Lots. Never had any issues. Any issues are usually due to improper oiling or a bad seal.
  17. Nov 22, 2019 at 12:05 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Toyota TRD intake use K&N filter too.
  18. Nov 22, 2019 at 1:06 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Internet hysteria. I’ve used a K&N in my Tundra for 155,000 miles. Oil analysis’s are spotless.
    I’ve used them in dirt bikes, quad’s and my turbo SXS.
    Basic maintenance(dont over or under oil) and they hold up fine.
  19. Nov 22, 2019 at 3:07 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I use the OEM Toyota branded air box and filter in both my Tundra trucks, they work.
    If Toyota could have squeezed out more MPG without sacrificing durability & reliability, they would have used something else.
  20. Nov 22, 2019 at 3:28 AM
    Fro2671
    Fro2671 New Member
    2012 Tundra Limited, black, TRD crewmax
    2.5 level kit, step hoop bars, bull bar
    I use K&N filter. The gains are small. But it allows the engine to take in more and cleaner air. The throttle respond is a lil bit better also. As far as horse power and torque , maybe 1hp and 1.5 ft/lbs torque. Mostly it just saved from having to buy a new filter every few months due to cleaning and re using it.
  21. Nov 22, 2019 at 3:41 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Every few months? Where do you drive and how much?
    Rex Kramer likes this.
  22. Nov 22, 2019 at 3:43 AM
    Fro2671
    Fro2671 New Member
    Work on the pipeline. Off road as much as on hwy. Lots of dust and such. West Texas is very bad on air filters.
  23. Nov 22, 2019 at 10:29 AM
    559WeekendWarrior
    Menger
    Will it really depends on where you're at, your location. If you live in the climate of cold weather most of the time than a drop in filter will be best. For me I'm in California and I'm in the Central Valley where it's hot and nearly get cold or rain, so most of the time it's warm air. I run a custom homemade intake, Works the same as a aftermarket intake. However once I move by the coast I'll switch back to my factory intake and use a k&n or a trd filter, this way I don't worry to much about moist air.
    ryanryan34[QUOTED] likes this.
  24. Nov 22, 2019 at 11:17 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I've always used K&N drop-in filters on my vehicles. No issues and no complaints. On my Toyota's, I splurge and get TRD drop-ins. I did put an AirForce One CAI on my F150. Loved it but having an exposed air filter in your engine bay is not a good idea, I feel. If I had money to burn, I'd get the TRD CAI just for looks. The stock air intake is really well designed so other than a drop-in filter, keep your money.
  25. Nov 22, 2019 at 11:21 AM
    Jengel451
    The Bitterroot, MT
    Personal experience in Baja. Never again. Good luck though.
  26. Nov 22, 2019 at 3:43 PM
    ryanryan34
    Ryan
    Olympia WA
    So what would your recommendation be for desert environment with decent amount of dust and wind (El Paso TX)? Would it be worth while to do more than a drop in filter (K&N or TRD). Also background information eventually a CAT-Back or full exhaust is going to be added. Thanks again
  27. Nov 22, 2019 at 3:52 PM
    Rex Kramer
    Georgia
    Would a snorkel and maybe a high micron pre-filter help in those conditions?
  28. Nov 22, 2019 at 4:45 PM
    Professional Hand Model
    Hand Protectors
    I went to Baja for one day and ended up with dirty nails for a month!
    Beautiful but dusty!
    Cleaning and oiling a filter don’t sound like fun. Just use a paper filter guys and save your nails.
    Jengel451[QUOTED] likes this.
  29. Nov 22, 2019 at 4:51 PM
    15whtrd
    15whtrd Mr. Blonde
    I think I’ve read that S&B filters and intakes filter the best.
  30. Nov 22, 2019 at 6:10 PM
    Fro2671
    Fro2671 New Member
    Maybe would have helped. I just sit the bullet and cleared it every couple weeks. Was cheaper just to buy a couple of cleaning kits.
    Rex Kramer[QUOTED] likes this.
