Is there a fix for jumpy throttle just off idle?
Discussion in '3rd Gen Tundras (2022+)' started by Third-Reef, Jun 9, 2025 at 4:34 PM.
  1. Jun 9, 2025 at 4:34 PM
    Third-Reef
    Third-Reef [OP] New Member
    Gary
    2025 1794 TRD offroad
    My 2025 1794 non-hybrid ahs a jumpy throttle just off idle. Has anyone had a re-flash or anything that has helped with this?
  2. Jun 9, 2025 at 5:29 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    You mean it’s “responsive”?
    Describe “jumpy”?
    is it the same in the different drive modes?
  3. Jun 9, 2025 at 8:08 PM
    Third-Reef
    Gary
    Tryin to ease the throttle on from a stop, it almost like the pedal is stuck just little, then it moves and it's like i am a bad driver with a jerky start. The pedal is not stuck. Does not always happen. If i realy focus on pushing the pedal just so, it goes fine. It's just realy easy to have the first bit be jerky. Wife has commented on it also.
  4. Jun 9, 2025 at 8:12 PM
    Third-Reef
    Gary
    It's not the hesation some people describe where they give it gas and it does not go. If i step on it, it always goes. Its the first little getting it rolling from a stop.
  5. Jun 9, 2025 at 8:23 PM
    That literally sounds like the same thing
    aj350925 likes this.
  6. Jun 10, 2025 at 3:49 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I haven’t experienced the hesitation issue that some describe. Yours does sound different. These are throttle by wire, right? I don’t know what is used to sense the throttle input, but conceivably it could have a problem?
    If there is a software fix, the dealer should handle it.
    Maybe go to your dealer and test drive another tundra and compare?
  7. Jun 10, 2025 at 4:27 AM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    I'm experienced the same thing intermittently. From what I've experienced it's from a stop and feels like the pedal is sticking just enough to cause you to apply too much pressure and take off jerky/jumpy (not smooth). I don't feel like it's the throttle lag that some on the forum have mentioned as when Im driving and accelerate I don't feel a lag.
  8. Jun 10, 2025 at 5:10 AM
    aj350925
    aj350925 New Member
    You are describing the throttle lag problem. My truck has it too, I got a reflash to fix it, and that didn't work.
  9. Jun 10, 2025 at 5:31 AM
    hudrock
    So Cal
    25 MGM Limited
    Oh ok...I read some of those other threads and they are all over the place on what they are experiencing with throttle lag so assumed this was different as its very specific
  10. Jun 10, 2025 at 5:31 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    There might be varying degrees of the same problem. The throttle lag that some people report is a noticeable hesitation lasting a second, or so, after pushing the throttle. People have talked about almost getting into accidents from it when trying to quickly merge into cross traffic.
    The OP's problem sounds similar but less severe.
    Then there are many others, like me, who have never experienced any hesitation at all.
    Bulldog6 and hudrock like this.
  11. Jun 10, 2025 at 7:52 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    The new engine fixes that. I have the same thing. It’s the throttle lag discussed. It’s like sometimes it doesn’t pick up that the peddle has moved forward until engages and it jumps.
    Gepperso likes this.
  12. Jun 10, 2025 at 8:26 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    Toyota has denied it every time I bring it up. For me, it does go away after things warm up a little. If I'm not moving and shift into D, the truck will try to lurch hard so I need to be on the brake. Usually only once per drive session.
  13. Jun 10, 2025 at 6:20 PM
    LowcountryDave
    LowcountryDave New Member
    ‘23 Limited TRD
    This is pretty much the only quirk mine has as well. If the truck has been sitting for a couple of hours, and I shift from P to D, it'll lurch itself forward. I've found that if I shift to D and wait at least four seconds before releasing the brake, it won't throw itself forward.
    Toyota has given me the same response, and I've never been able to replicate it at the dealer.
  14. Jun 11, 2025 at 8:47 AM
    Gepperso
    Gepperso New Member
    Greg
    Georgia
    2022 1794 Smoked Mesquite
    Talon Garage Catt Shield, 2 K&N Air Filters, Thorton Chip Tuning
    As mentioned earlier I had the very same problem, However I was part of the engine recall. The new motor does not have the problem at all! :amen::yes:
    I'm still waiting on the TSB Break fix for the squeaky breaks when reversing in the morning. 3 :monocle:months now and counting...
  15. Jun 11, 2025 at 8:56 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Thats because it's not a 'lag'. There's probably little bit of reading comprehension on your end, gang. Mr.Hudrock clearly explains that it feels like pedal is sticking and then sort of like 'breaking loose', like a mechanical sticking of the pedal. Your problem wasn't fixed with a reflash, because it isn't electronic problem. Maybe the pedal mechanism needs some lube at the hinge.
