Is the TRD skid plate worth it just for oil changes?
Discussion in 'General Tundra Discussion' started by ToyotaDave, May 28, 2022.
  1. May 28, 2022 at 4:22 PM
    ToyotaDave
    ToyotaDave [OP] New Member
    I just did my first oil change on my 2019 TRD off road tundra. It is ashame toyota did not put in a access hole.
    Is it a worth buying the TRD plate just to make oil changes a little easier? My only concern is oil puddling up on the skid plate.
    I have thought about just leaving off the skid plate as i do not really go off road, if i do it's very rare but i plan to keep the truck for many years.
    Mike59 likes this.
  2. May 28, 2022 at 4:29 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Have to figure if your time is worth it, is the 10 minutes you fiddle with the plate worth the cost of a TRD or RCI skid?
    One thing's for sure - have a skid plate on there, even if the truck turns into a pavement princess. I decided to bounce a turkey on the highway off a skid plate once and the dent it put in the skid plate made me damn glad I had it on here and it wasn't something mechanical that took the bird.
  3. May 28, 2022 at 4:30 PM
    IMO the RCI is a much better looking skid plate. I would not run without one though....too much road debris. Pair a skid plate up with the MotivX tool kit and Fumoto drain valve and it will be the cleanest oil change ever.
    Booney, myt1, OHwendTrd and 3 others like this.
  4. May 28, 2022 at 4:32 PM
    ToyotaDave
    What is the RCI plate? I did buy the MotivX oil funnel.
  5. May 28, 2022 at 4:38 PM
    This is the engine skid by itself. They also have a transmission skid and an addon "winglet" set for catalytic convertor protection from theft. If you currently do not have any protection for yours cats, I would highly recommend that as a priority.
    https://rcimetalworks.com/https:/rcimetalworks.com/07-19-tundra-engine-skid-plate/
  6. May 28, 2022 at 4:48 PM
    ToyotaDave
    Nice! I do worry about the catalytic convertors and gas prices :spending:
    Oey12 likes this.
  7. May 28, 2022 at 4:51 PM
    Good timing with the 15% off too.
  8. May 28, 2022 at 4:53 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Short answer OP yes…
    An access door makes changing the oil significantly easier and quicker. And as @Tundra234 stated, an RCI skid plate is better looking. I have the aluminum version and my truck is an absolute pavement princess. Worth every nickel for the oil change simplicity.
    Retired...finally likes this.
  9. May 28, 2022 at 4:59 PM
    ToyotaDave
    My truck is black so i'm undecided which would look best.
    Oey12[QUOTED] likes this.
  10. May 28, 2022 at 5:01 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Mine is powder coated in black but I do believe they have a “raw” aluminum version…
  11. May 28, 2022 at 5:06 PM
    ToyotaDave
    Is the aluminum really as strong as the 10 ga steel.
  12. May 28, 2022 at 5:08 PM
    I have the powdercoated aluminum and it's pretty solid. Many of us here have the aluminum.
    Oey12 likes this.
  13. May 28, 2022 at 5:12 PM
    ToyotaDave
    That is the one i am interested in. plus 15 % off sounds nice.
  14. May 28, 2022 at 5:21 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    I’m getting too old to mess with taking off a skid plate every oil change hence I have the RCI skid plate.
    Tyman and Oey12 like this.
  15. May 28, 2022 at 5:47 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I bought the RCI plate after the third oil change. In that time, I decided to keep this truck long term, so it was a good reason to buy one.
    Giskk likes this.
  16. May 28, 2022 at 8:39 PM
    chingyeunglo
    chingyeunglo New Member
    I would say yes. And I would consider metal over aluminum because better protection and price although heavier but come on, I have the V8
    OHwendTrd likes this.
  17. May 29, 2022 at 4:10 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If you don't want to buy a different skid plate just cut a hole in the OEM and make a door or plate. This is what i did. There are threads on the subject.
  18. May 29, 2022 at 4:15 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    The aluminum definitely is strong. I used it to jack both front wheels up at the same time to put it on jackstands. Obviously do at your own risk but besides some nicks in the aluminum from the jack head it was completely fine.
    JakeVooDoo likes this.
  19. May 29, 2022 at 4:25 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I sold my OEM plate off my '21 on here for $100 and bought the RCI metal engine skid. Aluminum option was more $ and the minor added weight doesn't bother me. Install wasn't bad, second set of hands would've been helpful, just used a floor jack for that.
    x2. Run the exact same setup. Looking forward to my 10k change, 5k change was a little less than exciting- oem skid plate got in the way and I forgot to remove the red plug from my oil drain pan, got distracted for 4 minutes while draining and came back to a floor full of oil :anonymous:
  20. May 29, 2022 at 5:03 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Get a plate. Aluminum or steel. Both have their merit. Then get the MotivX and the Fumoto. Sell or trash the paper thin original skid plate. You will be glad for the extra protection and ease of oil changes.
