Is the -12 offset causing my new tires to rub?
Discussion in 'Wheels & Tires' started by amymills21, May 24, 2018.
  1. May 24, 2018 at 2:18 PM
    amymills21
    amymills21 [OP] New Member
    2018 Tundra TRD Sport 4x4 Crew Max
    2.5" Procomp Leveling Kit, 18" Fuel Sledge wheels -12 offset, Faulken Wildpeak A/T3W LT275 70 R18, Backflip MX4 Matte finish trifold, Husky All-Weather floor mats
    I just got a 2.5" leveling kit on my 2018 Tundra TRD Sport Crewmax. I purchased 18" Fuel Sledge wheels with a -12 offset. I also purchased Falken Wildpeak A/T3W 275 70 18 tires. I went to pick up my truck from the tire shop and they said the tires of rubbing on the bumper and the wheel well. From everything I have read and people told me, the tires should not be rubbing. My question is.... is it the -12 offset that is causing the rubbing issue? If so, if I go down to a 265 tire, will it stop rubbing? Or is the negative offset still going to cause it to rub?
  2. May 24, 2018 at 2:25 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    :popcorn:
    monaco730 and 15whtrd like this.
  3. May 24, 2018 at 2:25 PM
    Professional Hand Model
    Hand Protectors
    Cut your frame where it rubs and weld some supports in there. That will fix it.
    dandailey likes this.
  4. May 24, 2018 at 2:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes it's the offset. I would change the wheels rather than going with smaller tires.
    monaco730, 15whtrd and 831Tun like this.
  5. May 24, 2018 at 4:17 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    That is quite the offset
    joonbug likes this.
  6. May 24, 2018 at 4:29 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The +12 might not have rubbed, that -12 definitely will
  7. May 24, 2018 at 8:25 PM
    amymills21
    The only other options they have are +1 and +20 in that wheel. Do you think either of them would keep it from rubbing? Or would I have to get a whole other wheel style?
  8. May 24, 2018 at 8:29 PM
    amymills21
    Also, if I decide to just keep it as it is with the -12 offset, will the tires sticking out cause rocks and debris to hit the side of the truck? If so, what could I do to prevent that?
  9. May 24, 2018 at 8:32 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    +20mm should fix it. I ran +18mm with 295s and very very little rub, then went to 35s with only slightly more rub
  10. May 24, 2018 at 8:33 PM
    ninjajay
    Spoolston, TX
    +1 might be OK with a level, +20 would most likely be safe
    As for debris, fender flares will help but my guess is -12 is still too far out and there will still be some hitting the side of the truck
